ke10jr Posted May 23, 2011 Report Posted May 23, 2011 HI, I went about lowering my ke10 i put 2 1/2 inch lowering blocks in the rear leafs and got the front leafs sent away and lowered 2 inches when i put every thing back in the car only sat 1 inch lower than original height! how is this possible!!? where do i go from here?? thanking you in advance Quote
Jordain Posted May 23, 2011 Report Posted May 23, 2011 Hey mate.. Best thing to do is to remove the front leaf spring, Add a whiteline sway bar for it and get some thicker springs ( I think KE20 are the ones to use from memory ) Proper way: As for the rear... Go get the rear leafs gutted, everything taken off them, have the front eyelet flipped and as them to put 2 thicker leafs onto them.. I think the ones I put on mine where landcruiser from an FJ40 Dodge way for the rear: turn the leaf springs upside down 1 Quote
philbey Posted May 23, 2011 Report Posted May 23, 2011 This is the first thing you should do to get about an inch out of the front end http://www.rollaclub.com/faq/index.php?title=Lowering_KE1x_Front_using_KE2x_parts 1 Quote
Des Posted May 24, 2011 Report Posted May 24, 2011 HI, I went about lowering my ke10 i put 2 1/2 inch lowering blocks in the rear leafs and got the front leafs sent away and lowered 2 inches when i put every thing back in the car only sat 1 inch lower than original height! how is this possible!!? where do i go from here?? thanking you in advance Springs can take a couple weeks to settle. 1 Quote
kE20ME Posted May 24, 2011 Report Posted May 24, 2011 remove the front leaf all together, and run some decent front lowered springs- and philbey's ke20 strut top setup! 1 Quote
ke10jr Posted May 24, 2011 Author Report Posted May 24, 2011 Thanks guys been a big help il put some photos of the little beast soon :D Quote
