Banjo Posted October 31, 2005 Author Report Posted October 31, 2005 hey, banjo; check the rocker pedastals as well, i am losing a little oil pressure from there Not sure what you mean there Mike. Are you saying that you are losing oil pressure between the second front rocker pedestal & the head, where oil is fed to the rocker shaft ? The way I understand it, the oil feed to the rocker shaft is at a reduced pressure, and not at full engine oil pressure. The oil feed to the rocker pedestal & top of engine is fed via the second front camshaft journal. This journal has a hole right through it, so oil is only fed to the top of the engine when the hole in the journal lines up with oil holes in the block, which I presume is once or twice every camshaft rotation. The yellow Toyota engine bible has a picture of the lubrication system circulation that depicts just that. Someone, might have more insight into this operation, and I'll stand corrected, if I misunderstand this function. I once cranked a half reassembled 4K over, after assembly, to circulate oil around all bearing surfaces. I remember a squirt of oil emitting vertically intermittently from the oil hole in the top of the block (no headed fitted), that seems to support the operation as I understand it. I remember some early English Hillman engines, where the oil pump attached to the side of the block. The oil pressure relief valve was also removable from the outside of the engine. The only thing that was not accessible, that required sump removal was the oil pickup strainer. Anyone that has the worked on an early VW bettle engine will remember that the oil pickup strainer is accessible by removing a round plate in the middle of the base of the engine. Wouldn't it be nice if all the lubrication system components, were accessible without removing engine or sump. :jamie: Quote
mikeys toy[RL] Posted October 31, 2005 Report Posted October 31, 2005 that's exactly what i meant my rockers have been shimmed, the previos owner used pieces of rod bearings as shims they leak....... Quote
Banjo Posted October 31, 2005 Author Report Posted October 31, 2005 Mike, I think I have a set of original 3K cast iron rocker pedestrals here somewhere, that have never been skimmed or shortened. I can post over to the US of A, if you need. Bit long to wait until your honeymoon here next year ! Cheers ! :jamie: Quote
mikeys toy[RL] Posted November 1, 2005 Report Posted November 1, 2005 head shaved, pushrods won't fit under rockers, shim pedestals....all good Quote
Felix Posted November 1, 2005 Report Posted November 1, 2005 fair enough.... must have taken a bit off there. Quote
irokin Posted November 1, 2005 Report Posted November 1, 2005 If you change the height of the pedistals you change the way the rocker applys its load to the valve. Thats why roller rockers have ajustable height so you can minimise the side load on the valve. I can't remember how theyre supposed to be setup but it might be worth finding out. Quote
Super Jamie Posted November 1, 2005 Report Posted November 1, 2005 stock geometry is generally pretty good for minimal sideloading of valves increase valvelift 1.5mm, shave the rocker posts 1.5mm as well i don't think shaving the head would make any difference, that changes the angle and height that the pushrods intersect the rockers, not the angle the rockers wipe the head of the valve Quote
