while its usually quite simple, there a situations, where you go, wtf, am i even turning this the right, usually when on your back, the bolt is near impossible to access, and it all just gets a bit overwhelming, this is when this trick is good to have, I'm sure you have had moments under a car up to your elbows in grease getting to a shit of a bolt to undo it, and gone, "what f@$king way am i meant to turn this f@$ker now?"
Completely agree... when your turning yourself inside-out to reach a bolt you can't see and then try and figure out which way your turning it :bash:
