Zoidburg Posted May 6, 2011 Report Posted May 6, 2011 Hi everyone, My KE-30 2 door is currently running a 5K and 5 speed, and a 4.1 diff (according to the book). I was wondering if there's another diff or complete setup with disc brakes that will easily fit and preferably have the same stud pattern? I'd like a higher ratio diff than what's in there, so it revs less. Thanks :) Quote
Evan G Posted May 7, 2011 Report Posted May 7, 2011 (edited) you mean lower revs so it doesnt rev more. 4ac ae71 manuals have a 3:79:1 diff ratio so you can swap the centres but not the whole diff cause its got coils etc etc Edited May 10, 2011 by Evan G Quote
Zoidburg Posted May 10, 2011 Author Report Posted May 10, 2011 you mean lower revs so it doesnt rev more. 4ac ae71 have a 3:79:1 diff ratio so you can swap the centres but not the whole diff cause its got coils etc etc Okay, that should make a massive difference! Guess now I need to track one of these down and take the centres out. Thanks Quote
snot35 Posted May 10, 2011 Report Posted May 10, 2011 (edited) Are you sure? I'd imagine a 2 door KE30 has a jap diff. Check whether you have lots of bolts on the front of the diff, or the back. It's a big difference. The AE71 is bound to be a Borg Warner (bolts on the back). I'd actually check what ratio you do have. From memory quite a few KE30's come with 4.3's. Then you'll know what you have to look for. Edited May 10, 2011 by snot35 Quote
