Wonder how that conversion would go in PRC rallying. From memory, you have to run the standard block but no idea on whether the head has to be stock.....
No offence, that motor needs to be in a KE10 or KE20......
No good Col, for a variety of reasons that I can't tell you exactly, as I'm at work and can't be arsed trawling through the CAMS manual.
I gotta say that was my first thought as well.
  On 5/10/2011 at 7:15 AM, filfrederick said:
haha yeah that rob weirdo follows me around all the time, i think he wants to pash me. he is a bit like that.
here is some more pics.
and i will get some decent footage when i get a chance.
Yes he is weird like that, haha. I think after you made this engine he would want to pash you!
  On 5/16/2011 at 6:05 PM, tojo2 said:
8D Mean build . Thats a lot of boring, did you resleeve cylinders ?
No, I sonic tested the block before I started and just moved each bore around by a few mm just to get them in the middle of the casting so there was even wall thickness. I couldnt have bored them out as much as I did without relocating the bores.
my new cams should arrive next week!
294 8mm lift its going to be peaky.
think i will head up to lakeside sunday to watch the open wheelers sunday, apparantly there is a 130hp 3k powered one.
Are you taking this up there? i was thinking of having a look at said racing myself, will keep an eye out for you....
dude get this in a ke20 asap that poor motor needs less weight so it can really get up and go
like don't get me wrong I'm sure it pushes that ke70 quite well but imagine less weight get to use more of that power/torque
  • 6 months later...
  On 6/16/2011 at 10:32 AM, filfrederick said:
the rolla is almost ready for sunday! cams in and tuned enough.
wasn't able to finish my wheels so i will rolling on sportmax
see you all there
come and say gday
phil
how did you go, updates?
