  On 4/28/2011 at 8:35 AM, kickn5k said:
I'd imagine it would be same as 3,4k rockers.
Make sure you check lifter preload at the same time if you have changed the cam.
Stu.
Lifter pre-load in hydraulic lifter pushrod motors becomes an issue when the head thickness is changed (*shaving) or the cam profile is modified. Otherwise tensions are as standard. And for the above I think 40 pounds on the torque wrench would be plenty.....
Edited by GJM85
