G'day I'm converting the ke to manual at the moment and I'm up to dropping the auto out.
In the repair manual it says to unbolt the transmission from the bellhousing and remove the transmission, then the bellhousing after that?
Can't I just drop it all as one?
Thanks
Its how i did it. But then again, i did pull the whole she-bang out of the car first before removing the transmission off the motor.
From memory the torque converter was connected to the transmission shaft and the converter is bolted to the flywheel. I'm not sure on that one.
But i do remember having to go under the sump to unbolt the converter. Which, no matter how much oil had been drained from the auto, will still have a load of oil in it.
