Te71nanaichi Posted April 16, 2011 Report Posted April 16, 2011 Greetings from Land Below The Wind, Sabah ,Malaysia :) I'm new around here...found out this website after serious headache finding some bearings for my gearbox :bash: :bash: I Need Serious Help To Whoever can help me out here..i have problem with my gearbox...it has this whining/rattle sound..but when i press the clutch the sound would disappear ..when i send my car to open up and check the gearbox..my mechanic say its this 3 bearing i need to change, but i can't find it anywhere in my place...here;s the pic and the bearing code: Nachi 30RUSS4 C / 40 KOYO 205AN KOYO NUP205A/1d KOYO 04NUP0517 ive search on google...probably its the input shaft bearing..which one is it? should i really change all 3 of this bearing ...or should i identify which one is causing the problem..? i can't find anywhere around my place for this bearings...its been almost a month arghhh! I really-really hope someone can help me about this..cheers :D Quote
corollaart Posted April 16, 2011 Report Posted April 16, 2011 (edited) I would think its your counter shaft centre bearing ,have you tryed toyota ?I would think if this bearing is shot the rest are not far behind,i would do all of them. http://forums.club4ag.com/zerothread?id=9626 this may help rob Edited April 16, 2011 by corollaart Quote
Te71nanaichi Posted April 17, 2011 Author Report Posted April 17, 2011 (edited) On 4/16/2011 at 7:39 PM, corollaart said: I would think its your counter shaft centre bearing ,have you tryed toyota ?I would think if this bearing is shot the rest are not far behind,i would do all of them. http://forums.club4ag.com/zerothread?id=9626 this may help rob thank you for the link........ive been checking price at http://www.toyotapartszone.com the price are just too expensive ive found some aftermarket bearings... all are KOYO and NACHI the only missing bearings are the 3 that i post...is there any aftermarket bearings available with? buying the parts from Toyota is my last choice if their arent any available source . Edited April 17, 2011 by Te71nanaichi Quote
