Mr 20valve Posted April 15, 2011 Report Posted April 15, 2011 Hey people just wanted to get some info on this b4 I start spending cash. Is it true that 2003 Sportivo brakes bolt on to a ae92/3 with no or minimal modification? Mainly the front setup is what I'm askin about. Any info would be useful. Quote
carbonboy Posted April 15, 2011 Report Posted April 15, 2011 On 4/15/2011 at 9:09 PM, Mr 20valve said: Hey people just wanted to get some info on this b4 I start spending cash. Is it true that 2003 Sportivo brakes bolt on to a ae92/3 with no or minimal modification? Mainly the front setup is what I'm askin about. Any info would be useful. Have you tried using the websites search function or typing 'AE92/93 brake upgrade' into Google? Quote
Mr 20valve Posted April 16, 2011 Author Report Posted April 16, 2011 Yeh googled it but nothing came up. I'll try again. Wats involved in putting r32 brakes on? Quote
carbonboy Posted April 18, 2011 Report Posted April 18, 2011 On 4/16/2011 at 12:30 PM, Mr 20valve said: Yeh googled it but nothing came up. I'll try again. Wats involved in putting r32 brakes on? Alot of work & probably just as much cash. For brake upgrade ideas for the AE92/3, try here: Clicky-clicky Quote
Guest Casey-G Posted May 2, 2011 Report Posted May 2, 2011 *if he didnt read it Brakes off a ae1XX and similar levin GTZ with the superstrut suspension will bolt onto the ae92 hub, as for discs st185 rotors turned down to 260mm and re-drilled to 4x100 will see a worthwhile upgrade as they are twin piston calipers with a much larger pad. series 2 ae92 calipers and discs are larger than the series one.. also worthwhile If its not too late to say so i have a pair of the superstrut calipers and st185 discs which are brand new I'm looking to sell. /my 2cents :P 1 Quote
carbonboy Posted May 2, 2011 Report Posted May 2, 2011 On 5/2/2011 at 11:23 AM, Casey-G said: *if he didnt read it Brakes off a ae1XX and similar levin GTZ with the superstrut suspension will bolt onto the ae92 hub, as for discs st185 rotors turned down to 260mm and re-drilled to 4x100 will see a worthwhile upgrade as they are twin piston calipers with a much larger pad. series 2 ae92 calipers and discs are larger than the series one.. also worthwhile If its not too late to say so i have a pair of the superstrut calipers and st185 discs which are brand new I'm looking to sell. /my 2cents :P PM sent re: bits for sale :wink: Quote
Boosted Posted May 2, 2011 Report Posted May 2, 2011 On 5/2/2011 at 11:23 AM, Casey-G said: ......... Brakes off a ae1XX and similar levin GTZ with the superstrut suspension will bolt onto the ae92 hub, as for discs st185 rotors turned down to 260mm and re-drilled to 4x100 will see a worthwhile upgrade as they are twin piston calipers with a much larger pad. ......... What wheels do the AE1xx calipers, diameter and offset, fit under ? Quote
carbonboy Posted May 2, 2011 Report Posted May 2, 2011 On 5/2/2011 at 1:51 PM, Boosted said: What wheels do the AE1xx calipers, diameter and offset, fit under ? For that particular upgrade you need 15" wheels minimum. Quote
Guest Casey-G Posted May 2, 2011 Report Posted May 2, 2011 Yeah with common fwd offset wheels 15" is pretty much a minimum but with epic dished wheels and some spacers, although illegal for road use would fit under 14"s in some cases 1 Quote
Guest Casey-G Posted May 2, 2011 Report Posted May 2, 2011 Carbon boy, I'll read your pm after work today Quote
carbonboy Posted May 3, 2011 Report Posted May 3, 2011 On 5/2/2011 at 8:58 PM, Casey-G said: Yeah with common fwd offset wheels 15" is pretty much a minimum but with epic dished wheels and some spacers, although illegal for road use would fit under 14"s in some cases Okay I stand corrected :y: they can fit under 14" rims but you need aftermarket with massive dish/offset or spacers, which are illegal for road use so I ignored that option. On 5/2/2011 at 8:59 PM, Casey-G said: Carbon boy, I'll read your pm after work today Sweet as mate! Hope the text message didnt annoy ya at work, I just get excited when I find something I'm after :laff: Quote
Guest Casey-G Posted May 3, 2011 Report Posted May 3, 2011 PM replied dude ;) I had heaps of FWD gear a month ago, shame i didn't advertise here.. Quote
