hey guys. i should be gettin a pair of quad lights for my 1983-4 slanty front ke70 turned flat front.
I'm just wonderin if the quads will need special brackets or anything to bolt in? any help is greatly appreciated!!!
Strangely mine are very close to the beaver panel but not touching , so I didn't have to cut my beaver panel and you might need to drill some new mounting holes so it lines up all nicely.
You don't need to cut the beaver panel if you get the DX beaver panel.
If it's standard Aus ke70 then you will need to cut a piece out.
You don't need to drill any holes if you get genuine quad headlight with brackets.
A fair bit of wiring too.
wellllzzzzz ok.. i have got them in now YAY
BUT! now what i have to do is get them all to work. i will have to splice wires and shit to do that buttt end result will look soooo dope hhaha cheers for all the help guys
