Super Jamie Posted October 21, 2005 Report Posted October 21, 2005 if it's not too much trouble, could one of you ke70 owners please measure the following in millimetres? horizontal distance between brake pedal to accelerator pedal vertical distance between top of brake pedal and top of accelerator pedal distance from base of accelerator pedal to floor, following slant of accelerator while at rest thanks ;) dodgy picture provided with color coding :harhar: Quote
rjenman Posted October 21, 2005 Report Posted October 21, 2005 well its not all squares like in your diagram unfortunately The accelerator pedal's surface is convex, so i measured it with the ruler sitting from the floor to the middle point of this curve, it's about 150mm its also convex on the sides of the pedals. with the brake pedal pushed in making it about the same level as the accel, its between 700 and 750 mm distance in between. thats from furthest point to furthest point. (_)<->(_) i.e. the shortest distance possible to measure from pedal to pedal distance from top of accel to top of brake is a bit hairy to measure too, its about 150mm do you need more accurate? man my footwell needs a clean Quote
rjenman Posted October 21, 2005 Report Posted October 21, 2005 other people should do it too just to make sure they get about the same as i got Quote
corolla_bitten Posted October 21, 2005 Report Posted October 21, 2005 hey there, i;m just measured, i got 120mm between pedels halfway down accelerator, 30mm from top of acc to top of brake, and 110mm from acc to the plush pile :harhar: Quote
rjenman Posted October 21, 2005 Report Posted October 21, 2005 oookay.... i think the details that i gave about HOW i did it would be different for his interpretation Quote
Super Jamie Posted October 21, 2005 Author Report Posted October 21, 2005 so it appears my chop-chop-weld-weld ke30/70 hybrid pedal needs to come over to the left about 10~15mm to be in roughly stock ke70 position. time for bending :harhar: thankyou very much for your time guys, i appreciate the effort ;) Quote
Xany Posted October 21, 2005 Report Posted October 21, 2005 its between 700 and 750 mm distance in between. damn man, you must have a very wide foot well..... :harhar: Quote
rjenman Posted October 22, 2005 Report Posted October 22, 2005 oh yeah its huge, i have the dump truck version of a KE70 don't mind me beng a tripper, divide it by ten. lol Quote
rjenman Posted October 22, 2005 Report Posted October 22, 2005 except for the pedal to floor measurement. Quote
