if it's not too much trouble, could one of you ke70 owners please measure the following in millimetres?
horizontal distance between brake pedal to accelerator pedal
vertical distance between top of brake pedal and top of accelerator pedal
distance from base of accelerator pedal to floor, following slant of accelerator while at rest
thanks ;)
dodgy picture provided with color coding :harhar:
well its not all squares like in your diagram unfortunately
The accelerator pedal's surface is convex, so i measured it with the ruler sitting from the floor to the middle point of this curve, it's about 150mm
its also convex on the sides of the pedals. with the brake pedal pushed in making it about the same level as the accel, its between 700 and 750 mm distance in between. thats from furthest point to furthest point. (_)<->(_) i.e. the shortest distance possible to measure from pedal to pedal
distance from top of accel to top of brake is a bit hairy to measure too, its about 150mm
do you need more accurate? man my footwell needs a clean
so it appears my chop-chop-weld-weld ke30/70 hybrid pedal needs to come over to the left about 10~15mm to be in roughly stock ke70 position. time for bending :harhar:
thankyou very much for your time guys, i appreciate the effort ;)
