hay people i am thinking that i may have a clutch problem of some type
when i got to select reverse (clutch fully depressed as it should be :) ) it grinds and this is when i am not even moving and acasionly when i go from neutral to first and the rest also it has plenty of clutch fluid
check your oil, after that may be sticky pressure plate, same thing would happen in my old corona wouldn't go into gear from neutral. Otherwise maybe just worn, does it slip at all?
