  • Replies 97
Now have a 180b sss SU setup to pickup, everything except for the carbs (trying to get the lot) is there, if I don't get the carbs then I will just pick some up off ebay.
Which type would you be chasing after ? The datto style or SU's ?
I have a set of datto carbs that i picked up from Old Fella. Had been planning on using them on the turtle but i'm thinking of going a different direction with efi.
Datto style?
These are just a 38mm or 1.5" SU, actual item:
  • 2 months later...
Didn't get the su's as I am sticking with the weber, I blew the head gasket in late May so the head got some loving while it was off, the head received 3 runs of 20 thou skims and 2 final 'finishing' skims for a total of 65 thou removed. The intake ports were ported to remove the bend and to straighten them out like that of a Toyota F series head and then finished off with a light polish.
With the current setup I am running about 50 degrees advance an E10 petrol and it goes fairly hard, all it needs now is a larger cam and maybe a side draft as it runs out of legs at high rpm.
Head off:
Skimming:
http://www.youtube.com/watch?v=0JXCXfn9GlA
Porting 1:
Porting 2 (bad pic):
Also stuck some 15x7 white sunnies on it as the 14x6's looked dull, also have some 2.5" blocks to go into the rear when I get time.
  On 8/21/2011 at 11:20 AM, Evan G said:
TREVS BACK!
In short bursts, yes.
I have been flat out getting a weekend in the past 4 months so I have not been on any forums.
  On 8/21/2011 at 11:37 AM, towe001 said:
Who's this Trev you speak of ? :hmm:
:laff:
Trev what trev I thought he died............ Apparently not
Looks like it'll be abit of fun when it's done man, good to see the old girl getting some loving :D
  • 4 weeks later...
New tyres on the back and now sits 2.5" lower in the rear (now sits level) thanks to lowering blocks, will get some pics of it and post them up.
  • 5 weeks later...
  On 3/13/2011 at 9:18 AM, Trev said:
Fix dent in passenger guard.
A truck ran over the front guard at work today, thankfully there isn't much damage and we settled on a very reasonable price so I am looking into getting a new bonnet + guards, fixing the cab dent and getting it resprayed.
