Hi All
Had one of those brain waves the other day, lexus v8 into a rolla. then got thinking, if I'm going to all that trouble y not put an irs into it and make it a total weapon. (4WD is way too hard!) for now
Picked up a complete soarer from sydney a few weeks ago, Chose from the collection of rolla "the chosen one".
Body only needs a little bit of work!!!
Looks like you have some work ahead of you, have you looked at lloyd smiths 1uz ke70 on here for idea's?
What're you doing about manual conversion on the 1uz? Haltech
-Jono
Regs for drift state nothing about it, but hillclimbs is the point of the build and sports sedans have no rules, 4l engine car needs to weigh 1100kg, thats about all the rules, can be a space tube frame.
lloyd smiths build is a good read, didnt want to copy his build hense the irs, manual convo is sorted, CRS bell housing, custom flywheel and custom clutch. looking at an autronic ECU
And it's that lack of rules that I love about Sports Sedans. Be warned however: if you've got a 4L you're in class S1 against 6L Chev's and turbo 13 and 20B's. That's why I've gone <2.0L turbo (using a highly strung CA18DET) that puts me in class S2, maximum NA engines of 3500cc, no turbo rotaries (well a 10A doesn't count.)
Also Wheel arch flares cannot exceed 100mm in width. Dam :(
Best of luck though, it'll be a wild ride.
Jordan
good luck with it mate, seems you have alot of work ahead of you but will be well worth it, i have seen a sr ae71 with silvia irs and it WAS blue plated here in qld.....
Anyways good luck with it and i hope it works out for you
