the car will not start unless the battery is being jumped off.
I hook the battery up to a meter and it says thats tha battery is good.
Both terminals can be disconnected while the car is running with no effect.
headlights brakel9ights work while the car is off, but nothing while turn over when i turn the key, unless someone is jumping the car.
Now I'm pretty sure its the starter, but i don't want to go buy one and put it on if thats not the problem,
Please Help!
thankyou
What sort of meter are you testing with? A voltmeter or an ammeter, or a discharge meter from a battery shop?
It sounds like the battery has a dud cell, so it puts out 12volts OK, but doesn't have a lot of storage capacity behind it to push out the couple of hundred amps needed for the starter motor.
Try the battery in another car, or try another battery in the TE.
Its possible but less likely that there is a bad connection in the wiring or solenoid that only works with some extra grunt from a second battery. The second battery doesn't add any voltage, its all still 12V.
DO NOT DO THIS!!!! This is extremely bad for your alternator as it will think it needs to apply full output with no where to go......
Also if your using a voltmeter and the car is running you should be getting 13.8 volts.
If you can start with a jumper battery but not without one I'd say the battery is screwed, if it's older than say 4 years I'd look into buying a new battery.
  • Upvote 1
i don't think that is entirely true.
after a bit of reading it seems this was only an issue on the old generators, where they were current sensing. (don't quote this!)
where as the voltage regulators on alternators these days are exactly that, they regulate the alternators output using voltage 'sensing', when you disconnect the battery you arent changing the voltage at all (but you are changing the current/load which is where the generators had problems) so its happy to keep on truckin'.
apparnetly with the generators when you disconnected the battery the load was significantly changed, and the voltage would tend to spike for a second before the sensing equipment caught up, which was what used to cause all sorts of problems.
pluss....ive hot swapped batteries from all types of cars (efi, carby, whatever, new, old) and ive never had a drama!
don't take read too deep into my little "Explanation", I'm not auto elecy or elec engineer, but thats my take on it all.
  • Upvote 1
  Quote
err... also guilty M'lud. :laff: Just left them idling and whipped the batteries over. With all these electronic computers in modern cars I don't think I'd be so keen to try it now tho'....
  • Upvote 1
While I was at tafe studying for my trade they always said never to disconnect the battery while the engine is running, I didn't bother to mention that you get massive volatge spikes when you do this which can cause serious damage to electronic components as it's a te31 and wouldn't have sensitive equipment on board.
I just re-read that and I'm not trying to come off like a know it all, just saying that it's the way I was taught. :)
  • Upvote 1
  • 5 months later...
  Quote
The charge light is on and the battery doesn't charge.
Your alternator has died... The charge light is telling you that the battery has a negative power flow.
Replace or fix the alty, probably brushes or a diode has died.
  • 4 weeks later...
yep replaced the alt. then had to find a wire that would hook up from 'ignition on' so the regulator would turn on. now everthin is chargin :y:
  • 8 months later...
So i have a good battery, a new charge regulator, a good ground, and my charge light is dim, unless you put it in reverse then it's bright. Been like that for 2 weeks and seems fine. Probably just a dying alternator?
