hmmmm sounds like a fair bit of work for a ke10 :blinks:
What about a r31 lsd diff ???? could that work or would that be to big and that :hmm:
see ya
jimi
Oh ok bugger :hmm:
yeah so ive heard but to find any of them in lsd is near impossible and heaps expensive :dance:
see ya
jimi
Nah, ta22 diff isn't THAT much wider than ke10. i had both side by side and the ta22 diff was only 25mm per side wider.
R31 diff's are heavy and the rear brakes are too big to fit the 13's i want to run. I had a quote and it 1750 to have one shortened because it'd need billet axles
yeah i ddint think ta22 would be much different but i would like a lsd on :lolcry:
:blinks: Thats a bit steep and yeah ur right with weight and wheel size
see ya
jimi
You can buy lsd's for ta22 diff's ;) The lsd in the r31's is pree shizz to be honest.
None of that soft lsd'ness here though, minispooled is the way to go :yes:
Same width i'd imagine, although from the look of that it has pumped guards, looks as though i might fit 9.5 steelies under my flares after all :P
Hahahha yeah but there expensive arnt they ????
Na minispool are not good for me cause ill spin out or snap something lol :lolcry:
see ya
jimi
I went through all this... R31's have a conical LSD so if you plan on doing burnouts don't go with an r31. Go R31 if you want a nice disc brake diff, but if it doesn't fit under your rims then scrap it. T series AE86 diff and shorten the housings yourself and then get the axles resplined = cheap.
Minispool or virtually locked LSD yo.
