SinisterRolla Posted March 1, 2011 Report Posted March 1, 2011 Hey mate sweet Pano just a suggestion but it would look awsome with the holden VXR blue its a sky blue with silver flake through it the name is actually Ardon Blue :D Quote
iwontarolla Posted March 1, 2011 Author Report Posted March 1, 2011 I might have to check that out cause that's pretty much the colour I want cheers mate Quote
iwontarolla Posted March 4, 2011 Author Report Posted March 4, 2011 (edited) Hey guys bit of a update. I finished putting all my new dash and what not in. Trimmed the carpet to fit, it's looking pretty fresh just need to do a roof lining some how now. Here's what it looks like. sorry for bad pictures. Also called the best diff place in Adelaide. Didnt under stand what a locker was. They said if it's welded it's going to coat $845 to fix I do believe that sedan and panel van diffs are diffrent right? Thanks guys keep tuned Edited March 4, 2011 by iwontarolla Quote
Evan G Posted March 4, 2011 Report Posted March 4, 2011 sedan = coil springs van = leaf springs Quote
iwontarolla Posted March 4, 2011 Author Report Posted March 4, 2011 so get a sedan and cut and weld the mounts from the panelvan back on? Quote
Evan G Posted March 4, 2011 Report Posted March 4, 2011 whats wrong with your current diff? its welded or something? go to u pull it and get another diff centre and take it to a mechanic to fit if your not confiendent enough to fit yourself Quote
Ben-89 Posted March 4, 2011 Report Posted March 4, 2011 Certain diff centres wont fit though, the leaf sprung vans has the jap s series while the sedans and local wagons had aussie borgwarner diffs fitted. A few options. 1, Source a wagon rear diff from a ke70 or ae71, they will be a borg warner and should mount up easily enough. Or 2, Look specifically for a flat front se spec ke70 sedan as it will have a factory s series centre. My original se ke70 had this fitted which I found suss however over time identical cars in wreckers or carparks have had this same diff fitted. :y: Quote
iwontarolla Posted March 4, 2011 Author Report Posted March 4, 2011 okay the guy said its locked but its probely welded. its winey and leaking and has lots of play in the left axel and theres abit of oil getting in to the brakes Quote
rian Posted March 4, 2011 Report Posted March 4, 2011 "bit of panel damage to the left hand well quite a bit, are they the same from sedan to the panel van?" A standard KE70 sedan either slant or flat front will have different guards, but I'm fairly sure T18 or the DX(I think?) model of KE70 guards are the same. Maybe someone else on here will be able to confirm this. Quote
iwontarolla Posted March 5, 2011 Author Report Posted March 5, 2011 Okay thanks overrated ke70 I'll do some research and hunt around Bit of a update finished off the inside no need really for pictures. Hopefully getting another pair of rims to suit the front tomorrow. And does any one know if air horns are legal? Quote
Ben-89 Posted March 5, 2011 Report Posted March 5, 2011 (edited) "bit of panel damage to the left hand well quite a bit, are they the same from sedan to the panel van?" A standard KE70 sedan either slant or flat front will have different guards, but I'm fairly sure T18 or the DX(I think?) model of KE70 guards are the same. Maybe someone else on here will be able to confirm this. With the standard ke70 guards, they should bolt on easily enough. T-18 guards will fit but there will be two issues from th top of my head. 1, The top corner of the guard where it meets with the door and a pillar will have a different profile, due to the different doors on the T-18 2, T-18 guards have a different pressing in the guard which is lower and is where it accomodates the rubstrip. :y: Heres a quick reference. Flat front is the best match for the van. Edited March 5, 2011 by "The Mint KE70" Quote
iwontarolla Posted March 5, 2011 Author Report Posted March 5, 2011 What cars why there? Because the lights are diffrent on the corners Quote
Ben-89 Posted March 5, 2011 Report Posted March 5, 2011 (edited) What cars why there? Because the lights are diffrent on the corners The white ke70 is mine, and the panelvan belongs to mate/RC forum member Paul. Its to show you how the cut outs where the top of the doors meet the guards are the same on the sedan or panelvan guards, Along with factroy stampings for bodylines etc. Yes the parkers, headlights, grille, bonnet, front bumperbar and scuttle panel are different. Between the two. If you have all the parts though, it should be easy to change over :y: Edited March 5, 2011 by "The Mint KE70" Quote
iwontarolla Posted March 5, 2011 Author Report Posted March 5, 2011 I think I might just bash it all out sounds easier then swapping all that Quote
FOOMAN Posted March 5, 2011 Report Posted March 5, 2011 Used to see this driving around Blackwood all the time, good to see it sold finally. Keen to see it when you've finished. Keep up the good work :y: Quote
