philbey Posted April 11, 2012 Report Posted April 11, 2012 I looked into those pretty seriously and was going to do it, but in the meantime MSD have released a programmable 6AL that does the same thing. I was just going to buy one of them (about 450 delivered from the US) Quote
iwontarolla Posted April 11, 2012 Author Report Posted April 11, 2012 Yea I looked on to both of them, but as I got the kit for 140 it's a big saving. Also my dads a industrial Electrician so there's no problem what do ever. There's just the one thing I have to build it up as the points ignition right? Quote
iwontarolla Posted April 12, 2012 Author Report Posted April 12, 2012 started on the ignition system, built the coil driver. then started on the min board, not done yet but most of it is on. any one who has built this system or has a knowledge on it please pm me i have a few questions thanks guys Quote
iwontarolla Posted April 15, 2012 Author Report Posted April 15, 2012 I finished off the ignition system. Just finding a pressure sensor so put on then test it out. Almost got the guard down, no pictures but looks like the other one. Still having problems with my diff one sides tucked ones sides not then its still not centered thinking about getting new springs made up for it. Quote
iwontarolla Posted April 17, 2012 Author Report Posted April 17, 2012 got stuck into it today, bogged and sanded my drivers guard. starting to look pretty good still got a bit of work to them but getting there. hopefully have the other side welded up by the weekend. also the diff isn't out of whack it depends how its parked so as long as its on flat ground its all sweet. i also thought i was having a problem with my starter motor and relay. turns out the battery pack is screwed. so put my battery from my pulsar in and started first time every time. also got 2 pretty bad rust spots, I'm a little unsure how to fix this area any ideas? I'm also in urgent need of a drivers side seat belt if any one can help out and i also need one of these Quote
iwontarolla Posted April 20, 2012 Author Report Posted April 20, 2012 i got stuck in to the washer bottle tonight. i linished all the pieces ready to be welded. its a little tricky tacking every thing together as 316 is nonmagnetic. this lead to a few tack welds not joining and burning slight holes. but once i got the hang of it it started working out fine. there's also a few spots that don't line up and are gaps. if i make another one i will have to change a few things for it to work. ill also have to work out some sort of jig to make it a tad easier. also when i first started tacking it together i didnt set it up to well so i blow a few tack welds but i have it all sorted now. Quote
B.L.Z.BUB Posted April 20, 2012 Report Posted April 20, 2012 Nice work, but I have to ask, is it worth it for a washer bottle? You can buy stainless washer bottle canisters on ebay for bugger all. Or mount a plastic one somewhere hidden. Quote
iwontarolla Posted April 20, 2012 Author Report Posted April 20, 2012 I'm kinda using it as a learning tool, and this is just like the stock one so its washer and radiator overflow. It should look pretty neat when its done as well. Quote
B.L.Z.BUB Posted April 20, 2012 Report Posted April 20, 2012 cool as, just asking. make me one? Quote
iwontarolla Posted April 20, 2012 Author Report Posted April 20, 2012 nahh all good. yea if you wont one, i don't know how much it would cost depending on gas. but if you like the finished product we can go from there. or even if you know how to tig weld i can get every thing cut out and you can weld it? Quote
iwontarolla Posted April 29, 2012 Author Report Posted April 29, 2012 finished off the hand controller for ignition. now i just got to figure out how to wire it up what coil i need and then ignition curve. if any one can help out with any of these it would be great. i also sanded back the bonnet got rid of the horrible camo bonnet, and started fixing some dents in it. all the supports have broken lose how would i glue these back to the bonnet skin? also working on the guards still, passenger side guard is all most up to being bogged. driver side is all most done. thanks guys. Quote
Subaru_kid Posted April 29, 2012 Report Posted April 29, 2012 Last pic is tuff!! I love a good pano van, all the best with the build mate! Quote
iwontarolla Posted May 2, 2012 Author Report Posted May 2, 2012 so i went to Elizabeth and gillman upullits today. Elizabeth was a was of time expect i found some things that i had to hide around the yards for next time. but the best find of the day was a baby blue ke70 wagon at gillman. since my hatch is dented and rusted alone the bottom, i thought i would pick up this overrated one. also got the boot seal as well. it was in great condition defiantly a upgrade to the torn one. also got a pretty overrated garnish thingy with the number plate lights in. just needs a polish and a paint and its ready to go. got parts to fix the lock on the back as well. Quote
bAKER Posted May 3, 2012 Report Posted May 3, 2012 (edited) Hey mate, nice progress! With the jaycar ignition, I used the stock cool, with it's ballast resistor. You'll need to source an igniter too. I ended up using one from a generic igniter from a 80s range rover. Make sure you use proper insulated cable otherwise you'll get crazy electrical noise. Edit: just get a standard efi map, program it in. You'll have to tweak the map as you go along. A dyno is probably your best bet, but it's possible going up nd down hills all day. Good luck! Edited May 3, 2012 by bAKER Quote
iwontarolla Posted May 4, 2012 Author Report Posted May 4, 2012 what do you mean by igniter? is that the coil driver? wiht the insulated cable do you mean connects the coil diver and all that or what? thanks for the info Quote
