25 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Alright, this is what I have to work with.
-have an '81 TE72 4door that's automatic but has super low mileage on the stock 3TC
-have a Holley 5200 carb which is basically a 32/36 Weber, just need a manifold adapter for the 3TC
-have a set of 40mm Mikunis but need a manifold for either 4AG/3TC
-have full 4age conversion from my GTS donor w/ cams and other upgrades
-have 3TC 5spd manual parts
As I mentioned, I have zero to no time at the moment but feel I need to do one of these things to keep my sanity. Time frame is limited to a weekend with help from potentially one or two friends if our scheds match up. At the moment, I'm dying from driving with an autotragic transmission, luckily this isn't my daily. My original plan was to 5spd the 3TC for now but then I thought, tossing in a carbed 4AG wouldn't be that much more work. I know a bunch of friends are happily revving stock 3TCs like there is no tomorrow but my end goal involves a G head. I have most of everything for each option but can't decide so please, put me out of my misery and give me your 2 cents worth!!! ;)
Please provide explanation with your choice.
Thx!
Edited by daCoupe
  On 2/23/2011 at 10:16 PM, Trev said:
Put the manual in it, if it still doesn't appeal to you then stick the 4ag in it.
this
id probably do the 4age conversion from your doner car since it has cams and other upgrades not to mention EFI over carby, newer engine etc. If you have it there why not?
Do you want to drive it or are you happy for it to languish in the garage for a few years in pieces? Like my Datsun 1600 that was last registered in 2001 !!
Do the manual conversion and the Holley, & drive it for the rest of the year while you get the 4AGE fully sorted and ready to drop in. When you have holidays you hit the 4AGE conversion.
I 'might' have more than just a weekend to complete whatever option I end up choosing, so I can spread this over a couple of weekends worst case. And before you ask, due to a new addition to the family, the majority of my time is now spent with the little man instead of the hobby which is a-ok with me!
If a 3TC really wakes up when mated to a 5spd and I'm satisfied with it, I could tuck away my 4AGE parts for a rainy day but I have a feeling I will be disappointed with a mostly stock 3T. Sure worked over 3T's make gobs of power but that involves money that I don't intend on spending with this option. I'm sure most of you know the benefits of going 4AGE (EFI, R&P steering, disc brakes...etc) and honestly, I should just do it but will have to sort out a few things first such as maintenance and wiring.
Anyway, thanks for the feedback thus far. I'm looking forward to getting this done in the near future!
If time is always going to be a problem then go for the 4age efi.
There is less maintenance with an efi engine (no carbs to tune for one). It will take longer to install the 4age but you will get that time back with trouble free running and will save money with less fuel cosumption.
Are EFi swaps really like that?? I figure that they needs all sorts of sensors and computers and wiring that won't be in an older car so you spend months hunting down odd problems that may not have occurred in the original EFi car.
Seems that way with the Altezzas, but they're trying to keep the climate control running and the other peripherals and end up blending two computers. I wouldn't really know, having never fitted EFi.
Any ideas from you guys that have done it??
If you've got yourself ahold of a wiring loom to go with the 4AGE engine it makes slotting it in that much easier. The main ecu is the only computer in the system so it'd just be the EFI specific sensors you'd need to install(pocketable items from local wreckers :wink: ). If you were me (or I was you) I'd be going with the doable-in-a-limited-timeframe option & manualise/bigger carb the 3TC. Get the joy you can from it & if the urge is still there slam in the 4AGE.
Oh, for the love of all that is Toyota, PLEASE don't put carbs on a 4AGE!!! :sob:
Edited by carbonboy
I have everything to do a complete GTS conversion which includes all harnesses, fuseboxes, relays, sensors...you name it, I've got it. Wiring will be the biggest job but I've got friends who can help eliminate the non-essentials etc. And what is so wrong about running a carbed 4AG?
Regarding my car, it was supposed to go in to commence restoration however the snow/ice from this week's snow storm has delayed my grand plans. Oh well, patience is a virtue right? ;)
  On 2/27/2011 at 2:28 AM, carbonboy said:
2nd link is dead and are you serious about Toysport because last I checked, they are so behind the times it's not worth the bandwidth. I mean seriously, it blows me away that they don't recommend building a 7AG when there are a bunch on the roads making respectable power. Thanks for your opinion but I know lots of carbed vehicles that scream and aren't terribly difficult to tune.
Anyway, thanks for all the comments.
Thx!
If your "gts" is rwd the 4age convertion should be fairly simple and reliable ,if you keep it stockish
Yep, my swapped SR5 has full running gear off a RWD Corolla GTS so hopefully it will be fairly straight forward except for the auto to manual conversion and wiring. I plan on doing a detailed write up on my FB page and an abbreviated version here.
BTW, my car is headed for the shop after work today to begin the restoration phase...can't wait! ;)
Cheers!
