Hey I'm just wondering if fitting a ke70 5spd would mean that you would have to modify the tailshaft?
if so what are the options for gearbox's in a ke10 with standard tailshaft?
cheers
You can run a ke70/55 5 speed gearbox in a KE10. You do not need to shorten the tailshaft, although you do need to get a ke30 Yoke and swap it onto the KE10 tail shaft. This is what I'm doing at the moment, Just haven't bothered to find a KE30 Yoke. I got this information from Toymods.
Regards.
I converted my ke11 from auto to
manual and the tail shaft from
auto was exact length for 5 speed and Also the yoke was the same it was just matter or changing pedal setup and putting 5 speed in and obviosly clutch ..
But there was no changes to tail shaft needed
Yes I have a ke55 box in ke11 and all I done was swap the 2spees auto gearbox for te 5speed and the tail shaft slotted straight in and bolted straight up to diff .. Nothing to change on tailshaft
Got a jap diff?
If so get a gearbox yoke from a jap diffed ke3x (4/5 speed doesn't matter), and graft it onto the front of your existing tailshaft with a new uni joint (part No. K5-A517).
cheers for the replys.. havent got a motor yet but i figure i may as well go 5 speed straight out instead of having to change it again later.
and also how is the easy way of telling what diff is in a ke10?
Edited by rke_011
Jap diff is sealed unit at back of centre housing .. The Aussie diff had bolts around outside of centre housing at the back
