ok so ive got a ke55 coupe with the square looking head lights and have just found a KE35 TE37 KE30 TE31 COUPE GRILL with the circle head light but before i go out and buy it just wanted to know if it would fit???
AND
Ke30 rear tail light
will they fit aswell ???
thanks
AND
thanks
Grill won't fit if you still use square headlights, it will though if you convert to round headlights, here is a link showing how it is done: http://www.rollaclub.com/faq/index.php?title=Series:K/Model/KE50/KE55/Ke55_Round_Headlight_Conversion
assuming your using ke30 sedan(4door) rear tail lights, they wont fit a ke55 coupe as the coupe lights are wider than the ke30 lights, ke35(2 door) coupe lights will fit a ke55 coupe.
Cheers, Crowie
Edited by Crowie55
