ive spent ages searching numerous different things along those lines and that club4ag link is good for the 20valve but the only 16valve pinouts they have are for the jap spec ae86 sprinter i need them for the aussie ae93 100kw 4age engine
parrot your common sense is not welcome here.
http://www.club4ag.c...hnical_main.htm
club4ag is where its at for ecu pin outs, though i think that may be the first google result.
He he.
Can I recommend, now that you have given us more information, the fourth on the google search list........
http://www.rollaclub...Wiring_Diagrams
Failing that, as Trev notes above, the pinouts are visible inside the ecu if you take the lid off. Sometimes the screws are a bit hard to undo though.
Edited by parrot
i think this is about as close as it gets for the aussie ae92 100kw engine.
http://www.club4ag.com/faq_and_tech_pages/ECU%20Japan%20AE92%2090-91.htm
i think that is what we used when we wired my mates engine into his sprinter.
just compare that to the labels inside your ECU once you pull off the lid.
the pin outs is quite easy to read off the board (i was suprised), so cross referencing that to the links we have posted should give you a good indication as to what is what.
  • 2 months later...
