bally Posted February 10, 2011 Report Posted February 10, 2011 Hey guys I'm currently putting a 4AGE bigport from an AE82 into my KE70 and I have it all dropped in ready to go with the harness attached and plugged up to the engine. Today I went to go plug in the ecu and I realised that there wasn't a 14 pin plug for the ecu? I'm pretty sure there is supposed to be one as that has the +B1,+ B and Batt terminals that I need power when doing the wiring from what I've researched. Also I couldn't find the 5 Pin plug for the relay located behind the ECU and the 3 pin round plug for the alternator? My guess is that I am missing a loom which is seperate from the engine loom? or is there something I don't know? Can anyone help me? Thanks Quote
Trev Posted February 10, 2011 Report Posted February 10, 2011 You need the dash looms that supply the power to the ecu. Quote
Trev Posted February 13, 2011 Report Posted February 13, 2011 How did you go, I may have these spare. Quote
bally Posted February 14, 2011 Author Report Posted February 14, 2011 i got it but i got ripped off from a wrecker... ended up paying $95 for the loom and then i realised i only need the 2 plugs from the entire loom! I've got another question to ask. -The 5 pin plug on the back of the ecu which is the fuel pump relay(COR Relay). Is the thick black wire for that just an earth plug? Thats what I figured it to be from following it back down? Quote
