Hey guys I'm currently putting a 4AGE bigport from an AE82 into my KE70 and I have it all dropped in ready to go with the harness attached and plugged up to the engine. Today I went to go plug in the ecu and I realised that there wasn't a 14 pin plug for the ecu?
I'm pretty sure there is supposed to be one as that has the +B1,+ B and Batt terminals that I need power when doing the wiring from what I've researched. Also I couldn't find the 5 Pin plug for the relay located behind the ECU and the 3 pin round plug for the alternator?
My guess is that I am missing a loom which is seperate from the engine loom? or is there something I don't know?
Can anyone help me?
Thanks
i got it but i got ripped off from a wrecker... ended up paying $95 for the loom and then i realised i only need the 2 plugs from the entire loom!
I've got another question to ask.
-The 5 pin plug on the back of the ecu which is the fuel pump relay(COR Relay). Is the thick black wire for that just an earth plug? Thats what I figured it to be from following it back down?
