Need Help !
Toyota 3k carbys came out with varying venturi sizes.
I need to find out the number stamped on the silver tag that is attached to the float bowl screws for the Carby that came out with the 25mm secondarys.
I have a number of these carbys but have mixed the tags up, I need to put the correct tag on the correct carby so I can get approval to race with it.
The 25 mm venturi can be identifyed but looking into the venturi and checking the number stamped on it.
If you have a few of these hanging around the shed, I would be forever grateful if you could check them out for me.
I suspect the number is 24373 but just want to be sure.
Thanks
Andy
