Ae71 member wont go without a lot of work. ke11 use a wishbone lower control arm with no castor rod. ae71 use a castor rod.
interesting point, however doesn't the suspension out of a ke20 bolt right in?
No, there is no provision for a castor rod setup unless you cut and weld ke20 sections in. Thats from what ive seen in my ke11 and ke20.
ah I see, sounds a bit time consuming. Although grated modding a ae71 crossmember and coloumn half to fit in is a pretty serious job in itself. There is a good reason I charge $850 for the job on the ta22's
I was told a ke20 cross member will fit with a little work into a ke10 or ke15 its the lower arms u have to mod ???? hmmmm :hmm:
see ya
jimi
Ke20 cross member bolts in, you need to find a way of putting the castor rod set up from the ke20 to the ke10. I'm not sure how this is done. I would say just mix and match some engine mounts on the stock ke10 cross member, take the leaf spring out and put some coil overs on with a strut brace and a sway bar. Will improve the handling a lot. Put an ae71 rack onto the ke10 cross member. Probably have to shorten it as Sam has mentioned.
putting the ae71 rack on the ke10 crossmember would be very difficult to do right and highly unrecommmended. A custom adjustable jig would be needed to be made off an ae71 crossmember to get it right.
Ae71 crossmember is obviously too wide, if you were to cut it down you would also have to cut down the rack or find a shorter alternative. This could affect ackerman angles etc, gets too hard to work out.
Ke20 crossmember just fits width wise but mounting holes are a little out.
I have done this and found it pushes the front wheels forward (caster). I couldn't push the crossmember back enough as it then fouls on the pitman/idler arms and steering linkages.
Other pictures i've seen with this done confirms the added caster.
Fitting a rack to Ke1# crossmember won't work too well because the lower wishbone arms get in the way.
It could work if you converted the wishbones to common lca's. A bit of work involved, an engineer should be consulted.
