I sussed it out. It's not an oil pressure issue. And it has nothing to do with the pcv valve i'm missing. I think the valve clearances were to tight and the timing is way out.... uncool but somthing I can rectumfy until I get the carbys on.
Pcv opens under vacuum. Which is why alot of older cars let off a puff of oil smoke after closing the throttle.
If the valve hasnt already completly jammed up...
