t18drifts Posted September 28, 2011 Author Report Posted September 28, 2011 here ARE SOME PICS FOR YOUR VEIWING PLEASURE OF THE PROGRESS Quote
white_sandshoe Posted September 29, 2011 Report Posted September 29, 2011 On 9/18/2011 at 11:22 PM, ke70dave said: looks like a pretty good buy t18drifts. i love the cooler setup, that is fantastic. has backyard mechanic written all over it. its one step up from a J pipe arrangement. admitedly a small step.... i was half expecting a hole in the bonnet after seeing the engine bay pic! This almost HAD a hole in the bonnet! lol. I wanted to, and heavily recommended it, since the front mount suggestion was turned down. lol. Looking forward to someone building a 3TGTE properly! Loving your work t18drifts. 1 Quote
t18drifts Posted September 29, 2011 Author Report Posted September 29, 2011 On 9/29/2011 at 12:42 PM, white_sandshoe said: This almost HAD a hole in the bonnet! lol. I wanted to, and heavily recommended it, since the front mount suggestion was turned down. lol. Looking forward to someone building a 3TGTE properly! Loving your work t18drifts. haha cheers mate looking forward to the end product and getting some help from you aswell down the track :) nO NO NO NO NO most defenitly not going to be cutting a whole in my bonnet proper front mount will be the plan AND THIS WILL BE RE REGOED WITH THE 3TGTE :wink: Quote
19914afc Posted September 29, 2011 Report Posted September 29, 2011 Are you going to get rid of the steering box while you have everything else out? just need a ke70 crossmember with ta22 mounts apparently. Although I have a AE71 crossmember at home and it looks identical to the std one just with rack mounts. Quote
white_sandshoe Posted September 29, 2011 Report Posted September 29, 2011 The steering column mounting through the firewall becomes an issue... Though I've got it under good report that some people have worked that out. The AE71 crossmember is the way to go when doing it, or an AE86 if you can find one. lol. the way the steering column comes through the firewall is completely different... KE and AE racks use a bearing on the lower half of the shaft, where the T18 doesn't as it's fixed solid to the box... Quote
t18drifts Posted September 29, 2011 Author Report Posted September 29, 2011 nah has no dolllars unfourtunatley but i can assure you that the motor will be out some time next year for forged goods and rebuild and a general freshen up but yes i will be looking in to that will be running t25 for rego then might look around for a t25g as its ball bearing instead of bush bearing got the coils in the front of charity tonight and started hand degreasing the 3tgte :lolcry: getting the engine bay ready for some new paint might stick the 3tc back into allie tomoro night and should have my awsome cnc'ed 3t to sr adapter plate for the manifold tomoro then will have to sort out the plumbing for oil and coolant for the turbo zeing as the ct20 was only oil cooled/lubed :wink: Quote
t18drifts Posted September 29, 2011 Author Report Posted September 29, 2011 On 9/29/2011 at 2:34 PM, white_sandshoe said: The steering column mounting through the firewall becomes an issue... Though I've got it under good report that some people have worked that out. The AE71 crossmember is the way to go when doing it, or an AE86 if you can find one. lol. the way the steering column comes through the firewall is completely different... KE and AE racks use a bearing on the lower half of the shaft, where the T18 doesn't as it's fixed solid to the box... [/quote :hmm: Quote
19914afc Posted September 30, 2011 Report Posted September 30, 2011 I will be doing the conversion soon, I have been told to use a KE70 steering column and steering shaft (all 1 piece I think? never had a look. I have other goodies to go in mine during the conversion as well. Quote
t18drifts Posted October 6, 2011 Author Report Posted October 6, 2011 (edited) HAY GUYS last night i dropped the 3tgte into charity finally still waiting on the adapter plate it will deffs be done tomoro then plumb up turbo and inter cooler and re wire the c**t and were all gravy Edited October 7, 2011 by t18drifts Quote
dashills Posted October 8, 2011 Report Posted October 8, 2011 Hey t18drifts , are you going to do front mount cooler , i would customize the intake chamber and throttle body upgrade . I have seen one on the net put out 700+ hp Quote
t18drifts Posted October 9, 2011 Author Report Posted October 9, 2011 um not at this stage i wont be changing the intake manifold as i am trying to keep it as simple and quik to get it roadwearthy ect as for front mount it should be happening not keen on cuting any holes in panels for cooler piping though :hmm: oh yeah found out the seals are phukt in my t25 today.................................................................... i think its T28 time :wink: Quote
Spencer[RL] Posted October 9, 2011 Report Posted October 9, 2011 T25's are pretty common and not overly priced tho. Quote
t18drifts Posted October 9, 2011 Author Report Posted October 9, 2011 yar but i may havr found a free t28 :rolls: Quote
dashills Posted October 10, 2011 Report Posted October 10, 2011 (edited) On 10/9/2011 at 2:43 PM, t18drifts said: um not at this stage i wont be changing the intake manifold as i am trying to keep it as simple and quik to get it roadwearthy ect as for front mount it should be happening not keen on cuting any holes in panels for cooler piping though :hmm: oh yeah found out the seals are phukt in my t25 today.................................................................... i think its T28 time :wink: run the piping under the front lower rad support , i've done this already Edited October 10, 2011 by dashills Quote
t18drifts Posted October 10, 2011 Author Report Posted October 10, 2011 On 10/10/2011 at 12:35 PM, dashills said: run the piping under the front lower rad support , i've done this already pics?:yes: Quote
