If you need anything Weber, give these guys a call;
Weber Performance Carburettors
03 9587 3277
www.weberperformance.com.au
They are in Mordialloc and have everything you might need.
Great range and pricing is pretty good. I dropped in yesterday for some filters and jets.
  • Replies 42
  On 1/15/2011 at 2:34 AM, ewt said:
wilson carberetters in airport west
he is an old guy and seems to know his shit about these things
well worth a try
ive used him on all my carbys for my show / modified cars
my 2 cents anyway
good luck
Woz
Yeh mate thats who I'm looking at taking it too, thanks for that(just around the corner from my work). Bit of an update. I put an electric fuel pump(inline 1-4psi for carbies) and it runs alot better. Still coughs some times. so still needs to be tuned. but i can nail it around a corner and it doesnt want to die (as much lol) now.
  • 5 months later...
Ended up ditching the stock carby and got myself a 32.36 i think. with a redline adaptor plate. modded up a bracket for the accelerator cable. needs tuning as it doesnt want to idle below 1200~rpm. think i'll take it to wilson carbies once its back on the road for a tune.
It probably needs the idle circuit cleaning out, the same as your stock carb did.
If they sit around and dry out the tiny chambers and drillings get blocked with resin and dirt, and if it gets free it often ends up blocking the jet.
The idle jet runs the car up to about 2000rpm when it finally hands over to the main jet, so idle jet problems make it lean for all that initial acceleration.
Let us know what jets you end up using in the Weber, there's a lot of guys got them on here.
the idles are too rich! i hadd the same problem with my 28/36.
there was a 60/70 idle in it and the idle would stay around the 2 grand mark.
now its currently got 45/50 and its down to 1100. (needs 40/45)
if you want me to have a play around with it pm me
Carbies been rebuilt so its not dirty at all (very clean). just working out what carby it is (32/32,32/36 etc).
Thanks for the offer Evan. i'll see how i go if i run into trouble i'll pm you.
pulled the jets out on the webber
air correction
120 - 110
main jets
135 - 100
From what ive read thats too small. So ive ordered some new jets
main jets
140 - 145
air correction
170 - 160
air corrections are still too small. go 170/190
and mains jets look a little too rich? it will run but some fine tuning will be needed
what idles you running btw?
not sure on idler. i'll have to pull it out and have a look(forgot to write that one down). I'll chuck the new ones in when i get it and go from there.(i'll check today on what the idler and post it up).
Just checked idle jets are 45/50
Edited by xris
ok . so the cars booked in for next tuesday to go to Wilson Carbies. Just so i can get the correct gear in before then a good base to start with would be?
Main Jets
pri sec
135 140 <- ive got 100, 135, 140, 145 to play with)
Air correctors
pri sec
170 190 <- ive got 170, 160, 135, 100)
Idle
pri sec
45 50 <- this looks good enough from what ive read.
Is there any other shops in the west/north that sell jets (other than Thornbury carbies or is that as close as i can get)(don't want to pay another $8 in shipping for a $7 jet from weber) Wilson didnt know if they had them in stock...
As i need to buy another air corrector (190) for my setup i think..
Evan I'm looking at you lol...
Edited by xris
