RA28GT Posted January 5, 2011 Report Posted January 5, 2011 Hey guys I've got a strange issue with my KE20 currently. I'm getting a clunk every now and then while driving coming from the rear passenger wheel. When I jack up the car and get the rear wheels off the ground I'm able to pull on the wheel and feel it pull about 1-2mm towards me, but this is only at a single point on the wheel. Ive already replaced the wheel bearing but they didn't seem to fix it? There was alot of play in the old bearing. And before anyway asks every bolt is very tight! Any ideas?? The Axel looked normal when i took it out?? Quote
Des Posted January 5, 2011 Report Posted January 5, 2011 but this is only at a single point on the wheel. Do you mean it has movement at a single point in wheel rotation ? Quote
RA28GT Posted January 5, 2011 Author Report Posted January 5, 2011 Do you mean it has movement at a single point in wheel rotation ? Yes, i can only feel the movement and the clunk if i pull on a certain spot on the wheel. By the way i feel absolutely no effect on driving as well. Quote
Des Posted January 5, 2011 Report Posted January 5, 2011 Condition of splines on the axle and inside the diff center ? Quote
RA28GT Posted January 5, 2011 Author Report Posted January 5, 2011 Condition of splines on the axle and inside the diff center ? On Axel as per normal, no signs of damage, can't say for the diff center because i haven't opened it up. The clunk that i hear comes from the drum end of things if that helps too. I'm stumped. Quote
Raven Posted January 5, 2011 Report Posted January 5, 2011 I'd be more inclined to say you may have a few teeth missing on the spider gears. Being a Jap diff, it may pay to pull out the centre and inspect it. Quote
RA28GT Posted January 5, 2011 Author Report Posted January 5, 2011 I'd be more inclined to say you may have a few teeth missing on the spider gears. Being a Jap diff, it may pay to pull out the centre and inspect it. Damn, sounds like a need a new center. I seriously can't think of everything else as its all been inspected. Anyone got a spare jap diff? Quote
Evan G Posted January 5, 2011 Report Posted January 5, 2011 (edited) if youve replace the wheel bearing and can still be able to get movement out the wheel SOMETHING AINT RIGHT EDIT - I'm not sure if you could shim the back of the bearing on these axles? therefore fixing the freeplay problem Edited January 5, 2011 by Evan G Quote
Trev Posted January 5, 2011 Report Posted January 5, 2011 A small amount of in and out movement of an axle is completely normal, Raven has posted a very valid point but before you go pulling the centre I would be taking the wheel and drum off and see what movement you have in the axle then. Quote
LukeAE71 Posted January 5, 2011 Report Posted January 5, 2011 (edited) Troy I may be able to help as I have a jap diff centre sitting here waiting for you, also a pair of axles in the rare event that your axle is up the shit. Let me know if you need it :blush: Edited January 5, 2011 by LukeAE71 Quote
Raven Posted January 5, 2011 Report Posted January 5, 2011 Also got a spare complete diff if required, but its a little noisy from memory, and that was outta my KE25. Quote
RA28GT Posted January 5, 2011 Author Report Posted January 5, 2011 (edited) A small amount of in and out movement of an axle is completely normal, Raven has posted a very valid point but before you go pulling the centre I would be taking the wheel and drum off and see what movement you have in the axle then. I don't have any movement in the Axle when i pull the drum off, i can't pull on it and get any movement. Its only when i yank (or hit) the wheel at the top (at a certain spot) it clunks. Its a distinct metal on metal sound, this happens while driving. Initially I thought it was a uni joint but they seem really solid. Troy I may be able to help as I have a jap diff centre sitting here waiting for you, also a pair of axles in the rare event that your axle is up the shit. Let me know if you need it :blush: I might have to take you up on that Luke. I'm going to rip the diff out this friday i think. See how i go. Edited January 5, 2011 by RA28GT Quote
Raven Posted January 5, 2011 Report Posted January 5, 2011 (edited) Just to give you an idea, those pins that hold the spider gears can cause issues. This is the basic layout of the Banjo (Jap) Diff. Pretty simple to pull apart, if you need a hand, let me know. :) Edited January 5, 2011 by Raven Quote
RA28GT Posted January 5, 2011 Author Report Posted January 5, 2011 Just to give you an idea, those pins that hold the spider gears can cause issues. This is the basic layout of the Banjo (Jap) Diff. Pretty simple to pull apart, if you need a hand, let me know. :) Ive changed one before, biggest drama it getting the axles out, as well as getting the drums off. The first one was a nightmare to remove. Any tips for me on axle removal? Thanks Mick. Quote
Raven Posted January 5, 2011 Report Posted January 5, 2011 Yep, bolt the drum on back to front onto the axle and give it a wack with a mini sledge hammer. Should drop out ;) Quote
