hi guys i'm wanting to upgrade the brakes on my ke30 i read on faq that you need the corona xt130
but could i use the struts and brakes out of a 85 corona st141? as i went to a few wreckers in the bisbane southside today and only found st141 models
cheers
Yes, but you may end up with excessive positive camber, or so i have read.
if i used the st141 and fit sigma lca wouls that help to pull the camber in?
Definatly!
With the ST141 struts you may find that te bottom of the wheel is tucked in further than the top. Fitting sigma control arms will probably still give you a bit of negative camber too!
Definatly!
ok cool thanks heaps for that i will have to head down to the wrecker tomorrow would you know what sigma control arms
i will need gh,gj gk? also can i use the corona spring and just change the top of the strut i don't mind if the front sits a bit high
if i'm using the 141 struts what steering arms will i need?
