comtoy Posted December 21, 2010 Report Posted December 21, 2010 this may have been covered before but search didn't bring up the info i wanted i have a KE35/55 hardtop corolla and am looking at running a fully worked sr20det in it and wondering what diff and brake setups people have run any help on setup's are greatly apprciated thanks guys Quote
BUZ440 Posted December 21, 2010 Report Posted December 21, 2010 i have hilux 4 pistons calipers up front, hilux diff 3.7 lsd up the back with ford xd solid rotors unsure of the booster i have can't remember have to have vented / solid combo to be engineered with the SR Quote
LittleRedSpirit Posted December 22, 2010 Report Posted December 22, 2010 Hello. Hilux are the go but look for something a little smaller than the E series if you can. F series are the go unless you are making stupid power. Then you can use LSD centres from Lexus Altezza, MA61, Crown etc. The RN47 2wd lux has a pretty tought little E series if you decide to go that way. The good thing about a Lux diff is it is already a leaf diff so will need minimal mods to be fitted, as long as you go for an earlier series of lux the width could be either similar or the same from the get go. I think RN25 lux has the right width of diff too. Quote
comtoy Posted December 22, 2010 Author Report Posted December 22, 2010 thanks for that guys also where can i buy coilovers for the front of it Quote
philbey Posted December 22, 2010 Report Posted December 22, 2010 Coilovers, best cheapest option would be the HSD sleeve kit from these guys: http://otomoto.com.au/HDSystems/sleevekits.htm Quote
Kriso Posted December 27, 2010 Report Posted December 27, 2010 I'm also on the build with a 55, anyone used the torago diff's before? Quote
LittleRedSpirit Posted December 27, 2010 Report Posted December 27, 2010 Torago diffs are f series and a bit wide to begin with. Quote
