hey all. for my ta22 celica i will be running bolt on flares my only q is to run the bolt on flares will i have to cut up my original rear guards? fronts doesn't bother me because if i do ill just get fiberglass front fenders.
this is the look I'm after
it depends on width/ offset of wheels and ride height, if you want it uber low with say 15x10 -26 challengers then youd have to cut the original rear guard, but you may get away with a roll or slight flair
