i have really low oil pressure in my 3k..
when at idle its about 5, and at high revs 6000rpm+ its about 20-30.
we have tried 3 types of oils in it. 25-50w, 10-14w, and sunthetic? or somnthing like that.
motors only about 1 month old and around 2 hours running time. its just got pulled down and the bearings are fine.
please help
cheers
  On 12/15/2010 at 5:53 AM, Felix said:
Were the thrust bearings and oil pump gears good? You could try shimming the bypass spring on the oil pump.
I'm not to sure. what do you meen by shimming the bypass spring? i no what it is don't get what u meen by shimming haha
  On 5/24/2010 at 11:11 AM, Evan G said:
sump must be off/dissy removed.
remove oil pump securing bolt (1 10mm bolt)
remove the split pin SLOWLY
spring will pop out with like a washer.
all 3mm of spacers (washers smaller than 14mm wide if i remember correctly)
push the spring in with the tip of long nose pliers
insert the NEW split pin and wrap it around the oil pump
HEY PRESTO
Found this using the search function.
Shimming means: http://en.wikipedia.org/wiki/Shim_%28spacer%29
Edited by eberbs
  On 12/15/2010 at 7:36 AM, TRD ke70 said:
Oil pressure relief valve could be stuck open.
yeah could be anything. the motors not here so can't really see those things. will be here staturday. what is ur presser at idle and high revs? in psi
  On 12/15/2010 at 9:06 AM, Trev said:
Oil pressure light coming on or not connected?
nah its not conneted it would be coming on thought.. orded a new oil pump today and put new crank bearings in. lets see how it goes i will be putting it in saturday morning and getting a new exhaust made up monday.
i had the same a low oil pressure problem with my motor, 9psi at idle and 40 psi at redline. turned out my engine builder left the timing chain tensioner loose :(
thinnist oil for a k motor i would go is 10w40
ahhk bort some of that oil yesturday. oil pump came from auto and wrong onee :I
