Hiro stop trolling wiki and writing it to make out you know it, it is fvcking annoying.
OP: There is a guy at road and track selling a rover v8 that needs to be assembled.
I didn't "troll" Wikipedia for it, I knew it. I was looking into the 3500s a few years ago (before I had any sense, in practice they're a horrible car). Plus, I had a Vitesse (the top-spec of the SD1) model car when I was a kid.
Is there many of them around?
Not as many as there used to be with rodders grabbing them, this one was meant to be going into a rod but he lost interest.
there are still heaps of rover V8's + gearboxes around if you know where to look.
i don't know why you'd bother tbh. i was looking into these a few years ago. with the usual mods that make a typical motor fly (ie mild cam, carb and inlet, good exhaust, decent comp etc) they only make 240-250hp.
for not much more than a worked rover conversion you;d be able to pick up a wrecked 2WD hilux or aurion etc and use the 1/2GRFE motor and make much more power. with an exhaust i think they'd sound sexy too.
Count the Aurion motor out. Its not going to mate to a rwd tranny, not even the GR series Hilux tranny from what i can tell.
I have access to a couple of aurion motors and some auto 1gr housings and they don't connect.
Having never looked at a lexus 6 speed pattern from a gr series motor I cannot say. I'm pretty confident that a 2wd hilux box will not connect to the smaller Aurion v6. Aurion motor pattern is almost the same as 2azfe, which is sort of a rotated s patetrn but different around the bottom of the housing. Its all down to the camry lineage.
If I were looking at a lexus v6 motor for my corolla it would be the 2.5 litre thing from the IS250 JDM version, with 6 speed of course. Looking at maybe 4-5k landed here but then you need a hell of an aftermarket ecu to run the 4 VVTi systems at once. Or you need to do a hell of a wiring job to make a standard ecu work in a non standard chassis. i think you would have to integrate the full electronics to make it function.
Edited by LittleRedSpirit
