hey, put a turbo 4k in my rolla and just got it going yesterday and its an bad need of a tune, does anyone know of any good places in adelaide hat will be able to tune a turbo 4K? it goes but as soon as it starts to hit boost it stops geting enough fuel so i need it tuned.
thanks
Get a gauge for sure. Is the reg a carbie style reg of efi? If it's an efi reg you wont get the base pressure low enough for the carb and you will be running the full pressure the pump can supply all the time. For instance, holleys run a base pressure of 7psi and dcoe style webers run about 3-4psi before they get upset. Your base fuel pressure should always be the same amount plus your boost pressure. So if you have 7psi base pressure plus 10psi boost your purl pressure should raise to 17psi.
Ok, enough rambling.
Throw some pics up of the setup so we can get a better idea of what's going on.
JP
