altezzaclub Posted November 7, 2010 Author Report Posted November 7, 2010 Well, go fit an oxy sensor and an FMD display and you watch it as you zig-zag for 7hours over the flat plains of inner NSW... It does change the mixture on the SUs with the cold air tube on, you can see it happen. Does the same if you draft a truck. Quote
Evan G Posted November 7, 2010 Report Posted November 7, 2010 well since he had a o2 sensor telling him that it would make a difference! Quote
daggers57 Posted November 7, 2010 Report Posted November 7, 2010 (edited) fair crack of the whip mate, no need to come onto it like a bull at a red rag. i think its great what he's done, and he did kinda prove that the wind direction was effecting the leanness/richness of the running of the carbies by using two oxygen sensors and an o2 meter. good work altezza I agree mate, good to see someone actually testing and proving their theories with the data to back it up. All too often someone comes along with an idea or concept that has no merit or validation, usually delivered with dubious statements like "my mate's mate's nextdoor neighbour's hairdresser's cousin did it and he got 1 billion kw at the wheels!" Mr Altezza, I take my hat off to you. You're taking budget rolla modification to a new level, and it's always interesting and informative to read your posts. And to ke20rollabus, blow it out your a$$. It's people like you who f@$k up decent forums! Edited November 7, 2010 by daggers57 Quote
KE20rollabus Posted November 7, 2010 Report Posted November 7, 2010 the car isn't going to run rich or lean depending on the wind direction! I'm a qualified mechanic, the only variation or the air fuel mixture is going to be in the jet sizes/ pump squirters, power valve etc. If you want to do something worth wile then run come ducting to the rad support panel for cold air. but of course you have a ke70, so you all know everything so continue to attach horrid cardboard scoops to your car :laff: Quote
KE20rollabus Posted November 7, 2010 Report Posted November 7, 2010 do you know what the normal pattern on a occiloscope of a oxgen sensor looks like? of course its a zig zag pattern, thats the sensor cycling from rich to lean! did you see what the fuel ratio was when going into and away from said wind?? Quote
Evan G Posted November 7, 2010 Report Posted November 7, 2010 the car isn't going to run rich or lean depending on the wind direction! I'm a qualified mechanic, the only variation or the air fuel mixture is going to be in the jet sizes/ pump squirters, power valve etc. If you want to do something worth wile then run come ducting to the rad support panel for cold air. but of course you have a ke70, so you all know everything so continue to attach horrid cardboard scoops to your car :laff: Quote
KE20rollabus Posted November 7, 2010 Report Posted November 7, 2010 yep real mature, no wonder i hardly come on this forum, too many people with ke70's and no idea Quote
Trev Posted November 7, 2010 Report Posted November 7, 2010 the car isn't going to run rich or lean depending on the wind direction! I'm a qualified mechanic, the only variation or the air fuel mixture is going to be in the jet sizes/ pump squirters, power valve etc. If you want to do something worth wile then run come ducting to the rad support panel for cold air. but of course you have a ke70, so you all know everything so continue to attach horrid cardboard scoops to your car :laff: Being a qualified mechanic does not mean shit, car dealerships hand them bits of paper out these days, wanker. Air delivery also affects the running of a car. Quote
Trev Posted November 7, 2010 Report Posted November 7, 2010 (edited) While we are at it, qualified mechanic you say? Here are some of your topics: K Series Efi Idea. need some help 4k Slow Jet Carby Q help Edited November 7, 2010 by Trev Quote
Evan G Posted November 7, 2010 Report Posted November 7, 2010 (edited) yep real mature, no wonder i hardly come on this forum, too many people with ke70's and no idea be a tool be expected to be treated like one edit - hi guys i have recently tyaken my ke20 to work to get the carby looked at. my mecahnic says that its not running rich enough at idle, even with the mixture screw turned all the way out. Aparently i need to drill out the idle jet, when i have looked at the work shop man, i think it might be the slow jet?? or is this just the air bleed for the idle circuit? ORIGHT MR MECHANIC! Edited November 7, 2010 by Evan G Quote
KE20rollabus Posted November 7, 2010 Report Posted November 7, 2010 so you know what the occiliscope pattern of a functioning oxygen sensor looks like????? ive worked hard for my qualifacation and they don't pass people who don't know what they are doing, but my years of experience don't mean much then?? what do you do for a living? Quote
altezzaclub Posted November 7, 2010 Author Report Posted November 7, 2010 Ah Tasmanians.. Ok, its running SU carbs, so they are NOT like your usual "jet sizes/ pump squirters, power valve etc." They will alter the mixture according to the airflow over the venturi base under the floating piston. So a cold-air tube to the front of the car will pressurise the airbox and push more air into the motor, although I suppose I'd have to rig a manometer to actually check that. I can tell you that fitting a scoop to the top of the airbox in a fibreglass bonnet lifted the bonnet and cracked it, so they can move a lot of air into a motor. ..and I did see the change in the mixture, as we were drivng in one direction for ten minutes, then have one corner, and drive that way for another 10minutes and have another corner. Seeing I'd recently fitted the oxy sensors and the FMD I was keeping a close eye on both carbs, and it was the mixture change from one straight to the next that intrigued me. Sure, you're a qualified mechanic, but you're still 40years younger than me, and that's a lot of engines to look at yet! Quote
KE20rollabus Posted November 7, 2010 Report Posted November 7, 2010 hahaha i like it how you just deleted my 'how to wire a electronic distributor' thread from your links :happy: Quote
KE20rollabus Posted November 7, 2010 Report Posted November 7, 2010 i did not realise you were running SU type carburettors. are they balanced correctly? what condition are the needles in, what oil are you running in them. Sorry but you have to admit that by reading the first post it seemed quite ridiculous. I am young but ive had lots of experiences working with many different engine, my old man is a fitter and turner, also mechanic, ive played with things form old v8's to morris marina's mate. Quote
greenmac80 Posted November 7, 2010 Report Posted November 7, 2010 anyway back on topic... can you give pics of the finished product? and just how strong did it end up being? Quote
