crunk81us Posted November 1, 2010 Report Posted November 1, 2010 (edited) i think, i cange my mind to swap engine. it's A big-big money down here... maybe just change a head engine to 5K i can do that buddy? What engine is in it now? "standard engine" = not enough info... I don't see any advantage to changing from (I assume 3k) to 5k head. Also "4 barrel carby" ??? on a k motor? maybe you mean twin carbs? for a bit more go cheaply, add a foam airfilter like a 'ram flo', extractors, sports exhaust, and add some more fuel to the mix. otherwise read : http://www.rollaclub.com/faq/index.php?title=Tech:Engine/K_Series/How_to_build_a_tough_K_motor Edited November 1, 2010 by crunk81us Quote
mughits Posted November 1, 2010 Author Report Posted November 1, 2010 What engine is in it now? "standard engine" = not enough info... I don't see any advantage to changing from (I assume 3k) to 5k head. Also "4 barrel carby" ??? on a k motor? maybe you mean twin carbs? for a bit more go cheaply, add a foam airfilter like a 'ram flo', extractors, sports exhaust, and add some more fuel to the mix. otherwise read : http://www.rollaclub.com/faq/index.php?title=Tech:Engine/K_Series/How_to_build_a_tough_K_motor yeah, i mean twin carb.... thank's for advice man? Quote
