  • 2 months later...
Bit of an update.. Car went back to the dyno touched up the tuned and got the eflex sensor working.. Works a treat.. Went to a local car show today and here are some pics.. Might hit the track next week
New p.b set at the drags... Went 10.6 128mph. Car went straight as a die all the way... But day did have its downsides, found with more boost, the engine isn't breathing enough, needs a bigger catch can and lines. Oil pressure went through the roof an spat out the oil filler tube.. Put oil everywhere :( also the gearbox is slipping a bit due to an issue that happened a few months ago, so it's coming out again... Pleased that it went into the 10's but there could be a low 10 high 9 sooner rather then later..
New number plates have been ordered
  • 3 months later...
  • 7 months later...
Bit of an update.. After a motor freshen up and a string of problems, the car finally got tuned and went out and hit the track last night... 2nd pass out went 1.34 to 60' and 6.3 to half 107mph, then backed off for an 11.1 77mph.. A couple passes in between trying to get it out of the hole better, couldn't do so and the last pass we had, we threw everything at it, still fried em off the line 1.6 60' and still managed a 10.3 131mph..
Here's a vid of the quickest run... Will have more vids up later
