13bke26 Posted November 27, 2010 Author Report Posted November 27, 2010 ok quick update, - haltech is in and wired - had to drill and tap the snout on the throttle body to accomodate the bigger air temp sensor for the haltech. - LS1 coils are mounted and wired. - First half of exhaust is welded up, up to the diff. - Cooler pipes are nearly done, throttle side done just gotta finish the turbo side. - Tailshaft loop is done, tail shaft is in, - rear end is completely welded up now - radiator is on its way from just alloy radiators. pics will be up soon Quote
13bke26 Posted November 27, 2010 Author Report Posted November 27, 2010 and the ratchet shifter is mounted Quote
ae824ate Posted November 27, 2010 Report Posted November 27, 2010 On 11/27/2010 at 10:26 AM, AE70 said: Pictures ? ^^ :y: :y: Quote
shy_77c Posted November 27, 2010 Report Posted November 27, 2010 Gday mate, first of the car looks like its coming around nicely. Secondly i am putting the convo pros on my ke30, my front rims are fine but do you have the exact size of your rear, including offset. I am about to order some from jegs.com. Thanks mate. Quote
LXY-642 Posted November 27, 2010 Report Posted November 27, 2010 loving the 26 mate. get some more pics up :) Quote
PHATKE20S Posted November 28, 2010 Report Posted November 28, 2010 :worship: I am proud to see that my old wagon went to such a great new home.... :party: Looking fantastic. Keep the pic's rolling in coz i am enjoying seeing progress....Something i could never seem to get happening :bash: Quote
13bke26 Posted November 28, 2010 Author Report Posted November 28, 2010 pics!! Ratchet shifter Engine Bay Rear end Made these flanges for the exhaust on the mill at work Half the exhaust Haltech PS1000 Just some of the fittings for the fuel system More to come during the week Quote
LXY-642 Posted November 28, 2010 Report Posted November 28, 2010 Not going braided mate? Noticed they are all push on fittings Quote
13bke26 Posted November 28, 2010 Author Report Posted November 28, 2010 yeah going push lock fittings, seen them used in previous applications and work fine Quote
Taz_Rx Posted November 29, 2010 Report Posted November 29, 2010 Most of mine are push lock, never had a drip from one of them. FYI - The straight are easy to fit into the hose. 90* and 45* ones ones the other hand are a bitch. I ended up with a bruise in the palm of my hand from doing them!!! Quote
LXY-642 Posted November 29, 2010 Report Posted November 29, 2010 From what I can see majority of them are not straight either. And good to hear that the push on works just as good :) Quote
Taz_Rx Posted November 29, 2010 Report Posted November 29, 2010 On 11/29/2010 at 1:11 AM, wpn36 said: From what I can see majority of them are not straight either. And good to hear that the push on works just as good :) Certainly do, if you've put one together you wouldn't doubt them. Tips for beginners when putting them together - Soak the hose in some HOT water for a little while prior. It'll make the hose slightly more flexi. Also wiping a small amount of grease or dishwashing liquid around the fitting or end of the hose helps. :wink: Also anybody thinking of using them - The fitting itslef isn't really any cheaper than a braided one, its the hose itself that can save you some coin. Quote
13bke26 Posted November 30, 2010 Author Report Posted November 30, 2010 yeah the guys at pirtek have told me what a shit they can be, and ive seen them done before.. the -6 ones arnt too bad to do, but the -10's are going to be the hard ones ... once i finish making the surge tank, ill start putting the fittings on the hoses.. Quote
