Ok my keto is crying for some fresh paint,
atm it is the faded blue colour.
i was thinking of going over the top in a white acrylic.
i do know alot of prep is required just wondering if anyone has had any good/ bad experiences with painting with acrylic.
how much do i need to sand of? obviously i know I'm not going to get a flawless finish just want it to look good from a distance haha.
car has no bog amd only light surface rust in some areas, i was hoping to use my dual action sander on the boot bonnet and doors and then go over with wet sanding and the rest wet sanding aswell, then hitting a primer wet sand again 2 coats of white then a coat of clear.
any thoughts much appreciated thanks guys
Wipe the whole car over with prepsol before you start, then wash off.
Wet sand all over with 600-1200 grit.
The idea is not to take paint off, but to roughen the surface, as soon as the shine is gone from the paint it is good to go.
I recommend to be careful with using machines, as you may ruin the surface flatness, will only take a few hours by hand.
Use a sanding block for all flats.
any rust spots need to be taken back to bare metal, treated and etch, undercoat used.
ok this sounds easier then i thought, should i use a specific primer? or any automotive primer from supercreaps will do the job? aslong as its not a 2pak primer i gather.
and what about thinning is there a ratio i should follow or just whatever sprays nice without dripping?
thanks for info so far :happy:
I got told 50/50 but no idea if thats true so don't go doing that :) Best to go to a paint shop to get your paint and primer I went with a mate and he got 4L of paint 4L of thinners, wax and grease remover and a mixing container with ratios written on the side for $200.
For my paint job we used acrylic basecoat and that was mixed 1:1 with R198 basecoat reducer.
We used 2pac primer and clear on mine but the process would be the same i guess.
Layed the primer down, hit any runs with 320, then took of the orange peel with an 800 wet sand.
A few coats of colour
Then 2 coats of clear (i have a flake in the 1st coat, 2nd coat with straight clear so we could polish it)
Edited by SLO-030
ok currently rubbing the car back i started with a 400 grit then going to go over with a 800.
picking up paint this sat ill let you guys know what i get and how it turns out :wink:
