Teddy Posted April 24, 2008 Author Report Posted April 24, 2008 Yeah, I'm not 21. I feel about 1/2 that age at the best of times, hahah. Should be quite a good weekend :y: John should have my dori-dori trims ready next week, if all goes well. The Order of what i will be doing on the weekend. I am hoping to get through atleast 3/4 of that list. Pictures will be proof of work :yes: 5° - Finish installing boot wiring solder joints and affixing it to roof of boot 6° - Find road worthy tyre / rim setup, find tyre brace & wheel jack. Install 21° - Cut carpet underlay from clutch pedal area and adjust free-play, again as required 10° - Fiberglass top steering wheel cover and install security light 23° - Find and install blower controle bulb, install its cover over 12° - Install lower steering wheel cover, dash face panel on right, Boss kit and Steering wheel. 13° - Install instrument cluster (stock for now) and surround. 11° - Replace gearstick bushes (on end of gearstick & in housing) 15° - Finish attaching breather line under car for carbon canister 20° - Install under tray under sump 18° - install indicator lenses again 19° - purchase and install new oil cap for rocKET covers. 2° - Tighten the fuel breather line for the filler neck on the tank end (need Smalllllll screwdriver or 1/4 inch tool(s)) 3° - Install the rear inner guard plastics 8° - Rust proof inside front doors 14° - Replace Tailshaft output seal on gearbox, fill up with oil If i can get through most of this, thats 1/2 the list completed :) Ted Quote
Teddy Posted April 24, 2008 Author Report Posted April 24, 2008 Just for bad luck, i had to take the Post no. 888 :yes:. ... That is bad luck, isn't it? Quote
Redwarf Posted April 24, 2008 Report Posted April 24, 2008 Are you doing your RWC at work, or would you like one that I can organise? Quote
Kid-Ae Posted April 24, 2008 Report Posted April 24, 2008 Just for bad luck, i had to take the Post no. 888 :yes:. ... That is bad luck, isn't it? Not bad luck, just ALOT of posts! Wow that list is getting so much smaller! Keep it up dude, don't cut your hair until this is all done :y: Quote
7shades Posted April 24, 2008 Report Posted April 24, 2008 Actually if you cut your hair now, you'd have enough to do your door trims :yes: Quote
Kid-Ae Posted April 24, 2008 Report Posted April 24, 2008 Retro Teddy-Shagpile door trims? :yes: Quote
Teddy Posted April 28, 2008 Author Report Posted April 28, 2008 Ok, Will add pics later on, camera is currently out of my reach, and my romp aint movin untill dinner time :wink: 6 of the items on that list were completed, So not that big a weekend, but still made some good ground. Next weekend will be alot larger.. No family events to tend to. Saturday arrival will be early, and departure quite late. :lolcry: Quote
78_7kRolla Posted April 29, 2008 Report Posted April 29, 2008 Great to hear your still chugging along teddy. The anticipation is building! Can't wait to see some piccies. Matt. Quote
Teddy Posted May 3, 2008 Author Report Posted May 3, 2008 In Red - Done In Orange - Doing Today In Black - Left To Do. 1° - Modify and install the remanding inner guard clips, for the front wheels 2° - Tighten the fuel breather line for the filler neck on the tank end (need Smalllllll screwdriver or 1/4 inch tool(s)) 3° - Install the rear inner guard plastics 4° - Re-seal rear talights, lense glue has dried up and cracked as its been there so long 5° - Finish installing boot wiring solder joints and affixing it to roof of boot 6° - Find road worthy tyre / rim setup, find tyre brace & wheel jack. Install 7° - dillevery of overrated grandma door trims to trimmer to finish of my door trims! (doing tomorrow arvo) 8° - Rust proof inside front doors 9° - install door trims & relating on doors 10° - Fiberglass top steering wheel cover and install security light 11° - Replace gearstick bushes (on end of gearstick & in housing) 12° - Install lower steering wheel cover, dash face panel on right, Boss kit and Steering wheel. 13° - Install instrument cluster (stock for now) and surround. 14° - Replace Tailshaft output seal on gearbox, fill up with oil 15° - Finish attaching breather line under car for carbon canister 16° - Install radiator fan & get shroud made, install fan temp on control unit. Put Foam on - Fabricate mounts for foam to sit on. 17° - Put new tyres on rims and install 18° - install parker & indicator lenses again :cool: 19° - purchase and install new oil cap for rocKET covers. ;) 20° - Install under tray under sump 21° - Cut carpet underlay from clutch pedal area and adjust free-play, again as required 22° - Re-install timing belt cover and fan belt. Get tony to listen to motor rattle 23° - Find and install blower controle bulb, install cover over that. 24° - lower vehicle to ground, and with some load, tighten rear diff bushes 25° - Lights Test & install numberplates 26° - Final vehicle Check over, I'm sure theres something small ive missed. 27° - D O N E - F O R - R O A D W O R T H Y - A N D - M O D P L A T E ! ! ! ! ! ! ! Quote
love ke70 Posted May 5, 2008 Report Posted May 5, 2008 (edited) if its it got teddy in it, ill be riveted :POSTPICS!: Edited May 5, 2008 by love ke70 Quote
love ke70 Posted May 5, 2008 Report Posted May 5, 2008 well its been 4 years, why rush the last couple of weeks? :POSTPICS!: Quote
7shades Posted May 5, 2008 Report Posted May 5, 2008 well its been 4 years, why rush the last couple of weeks? :POSTPICS!: Sounds like a quote from Gee Dubya Bush Quote
Medicine_Man Posted May 5, 2008 Report Posted May 5, 2008 Only if they polish the head of every rivet, lay them out on the bench in the sun and take a 9600 x 5600px 53mb photo and then upload them Pics of car finished and on its first weekend outing or BAN :POSTPICS!: I'll polish your nipples with a wire wheel, take them out in the sun and take 100 mega pixel pictures and upload them for everyone to see.. While you are up here next weekend to come on the test drive bitch! Quote
