The list of the TO Do's.
Finish off dash
- Make plastic acrylic covering mold, then get sent away to be made into acrylic (need to measure holes for digital clock and speedo odom reset)
- Create gauge mounting cups for gagues to sit in behind dash thats been made
- Mount gauges for test fit, mark and remove
- Make the LED concole assemblies for the lights (converting to LEDS; make up mind on what part is what colour and what strength)
- Install the LED backng for the lights, purchase and install lights, get jason over to help with wiring :hmm:)
- Finish off blacking out the dash
- Final install the gauges
- Test wiring, make sure its all ok; make sure it can be unpluged at centeral location for dash instalation and removal
- Tint the new purspex window (that covers the hole lot); test for darkness
- Seal & Install new window covering
- Final check over
- Remove entire assembly and store untill put into vehicle
Fuel System
- Repaint bottom of fuel tank as scratched badly. Clean out inside of tank.
- Paint top of fuel sender unit
- Paint straps for fuel tank, clean up 2x rubbers. Clean up pins and hooks.
- Finish mounting brake and fuel lines underneath, paint 1 more clip and install
- Get the connections of Ant. for fuel system, the correct ones :)
- Useing the newly ADR approved fuel neck filler for unleaded fuel, Paint then install onto tank. hand brush Paint the 8x bolts for it as well.
- Get new fuel pipe & clamps from tank to lines. Install pipes and connections; Install fuel tank. Connect up and install straps.
- Connect up fuel rail and fuel lines up front. Purchase new fuel filter and install.
- Check return line & breather line ok; paint and install carbon canister in engine bay accordingly. (away from airbox); pipe up using new 5mm spegiti black hose.
Brake System
- Once brake and fuel lines pipes underneath have been installed;
- Install diff to body brake line (Source a new one)
- Clean up, re assemble and install front calipers and brakepads
- Install front brake lines from struts to body
- Remove Brake m/ cyl and clutch m/ cyl. Bench bleed.
- Paint front brake metal lines; install. Same with clutch line to gearbox. (install clutch slave as well)
- Carefully install brake and clutch m/ cyls.
- Bleed system, using about 20 million L's of brake fluid :lolcry: - Brake and clutch
- Handbrake - Attach the 2nd mounts underneath for celica handbrake cables. Paint.
- Mount handbrake cables, Install inside mech. Adjust and check. 3 to 5 clicks.
Cooling system
- Purchase Ae86 Radiator
- Mount and install radiator
- Gather and install custom radiator pipes
- Install heatercore inside
- Install new heater pipes
- Install new thermostat
- Make custom mounts for thermofan; install thermofan
- Turn heater flap to open, and pressure down-fill the system. Check for leaks.
Intake system
- Mount EP92R Airbox. Measure and find connecting pipe accordingly. Make proper intake for airbox (custom 1 off)
Exhaust System
- Clean up, polish extractors and exhaust pipe. Paint exhaust thats not polishable chrome silver (approraite grade paint for temps :yes:)
- Install exhaust system
Note: exhaust needs CAT and pipe over diff; need to get it to an exhaust shop, and will bother about it when i get to this step.
Motor
- Make and install cold idol plate
- Connect up intake manifold and pipes.
- Replace Spark plugs, Dizzy Cap, Leads.
- Remove, clean up, paint and re-install cam cover. New sticker for 4age.
- mmm more to add here. Brain fart, can't think :P
Wiring (motor)
- Clean up wiring, Install wiring over motor. and onto inside.
- Process of cleaning up and installing (Wiring is correct, as i drove the car in before we striped it :P)
Dash
- Install entire dash; wiring and all for the dash ONLY.
- Mount ECU accordingly.
Note : Aircon will be put in later on once car is rego'ed and all.
Accessories:
- Bumpers to be put on last, to protect them.
- Clean up and redo twinheadlight front end setup. Clean up and paint mounts.
- Install tail lights, fender lights, front lights.. etc
- Install body molds where applicable
- Install new door rubbers / boot rubber / chrome accessories . Finish puting doors back together inside.
Wiring (body)
- Install body wiring. Replacing Firewall gromets and body gromets where appliciable. Clean up if nescessary
Interiour
- Install new interiour
Spanner check entire car.
mmm think thats basically it. too Tyred to think any more :P
first of all, NICE!!! second, with the radiator, as an idea, ST165 celica is the same size (frontal area) as a sprinter rad but its double the thickness. Same mounting points and all, not sure about inlet/outlet positions tho. Also comes with twin thermos that bolt up and look nice and stock :P
just a thought :)
^^ ahhh thats the one :D
ill be looking into that asap !
Few small updates.
- Sending plastic from dash away to get molded next week (acrylic clear cover )
- Got new boot rubber. Checking balley chanel rubber, as i now have samples :y: (slight complecations)
- Got 4x L of tectol .. love the rust prevention goooooob !
- Got the last 2x genuine fender blinkers in AUS (possibly the world) for a ke70. Stoked !!
- Tomorrow, going to install fuel tank and paint a few more brake lines up front.
Yee Haa !!!!
^^ sure did ! and its sitting in my car atm for you, will have to .. mm.. get it to you after i come back from MEL !
Ted
Also, got some work done today. Fitted boot rubber, tight fit omg omg, started blacking out interiour floor (make it neater), cleaning up / assembling / etc fuel pump / sender unit / etc parts, as previous owner did a very.. mm 1/2 assed job at it LOL
Ted
Which car, Bluey or Whitey?
I was hoping to come and get it tomorrow but that doesn't seem possible now, unless it's at Bajic central :D Otherwise, when are you back from Melbore?
You want anything for it?
Cheers, Matt :y:
i jsut read this topic start to finish and OMG! you are inspirational, and i thought i was a die hard corolla fan but never would i be commited enough to start a full resto like this..
hottest colour evva.. as for the trivia side... what corolla does it come on..?
i will b readily checking this thread for updates...
  • 4 weeks later...
haha thanks guys :yes:
Its an acrylic paint as such, with many 'iso-2pack' clear coats on top. Its amazing how.. bling? it looks in real life lol.
More work 2 be done on weekend :D !
