Gday
Hunting how to find some new drum brake circlips that go on inside and outside of brake shoes on rear of KE70.
They look like strange open-ended washers about 1cm diameter (don't quote me)
Does anyone know where to buy them new or what they are called?
Cheers
Do you mean the little shafts, springs and washers with a slot that hold the shoes to the drum assembly.
If so I've got a set I could send you if you ask nicely! :wink:
Spring retainers? I found a picture on the net.If thats them you can get them from toyota for about $1.50 each or something there ones from a hiace theyll know what you want if you bring in an old one.<br>
NOT the spring retainers!
the pin i'm talking about goes through the very top-most hole of the brake shoe.
Its like a ROUND washer, except for the end bits that go a bit skinny.
I've attached a quick sketch of the shape below:
Uploaded with ImageShack.us
