benno81 Posted October 16, 2010 Report Posted October 16, 2010 gday looking at putting a 4age into my ae93 its currently a 4afe a few questions 1 the motor iam looking at has a cracked crank i know the one in my 4afe is good will it fit in?(yes i will be grinding and fitting new bearings) 2 the motor has no dizzy or ecu hard to get? what sort of price for these items? 3 will my current fuel pump work with this motor ? 4 will the 4afe throttle cable fit? thats about it its a 20v silver top any info appreciated cheers benno Quote
chrismiass Posted October 16, 2010 Report Posted October 16, 2010 1 The crank on the 4afe and the 4ag 20v are completely different the flywheels bolts on a 4afe is 6 holes and 4age 8 holes . 2 The ECU shouldn't be to hard to get can source them of ebay but they have a couple of different types so would need to make sure it will plug in . 3 The fuel pump you have in your car now should be just fine for a standard 20v . 4 The throttle cables are different if you can mod it to fit maybe not to sure on this one . Quote
