just picked up a bargain from work today {bundamba wreckers} ke70 with a 5k so now i have a ke70 {5k} and an update ke70 {4k}
so far i have 3 engine ideas these are
turbo 4k
turbo 5k
turbo 5k with 4k head this idea because bloke i know has this motor n/a and after shaving 100 thou of the head has compression around 10 -11 to 1 is what he told me
so far i only know what ive been told about the k engine so help is definatly needed
and yes i did fail english so don't mind the spelling
turboin a 4k is not really worth it 5k is better. don't put the 4k head on! The higher compresson is not good for turboing blow the head of with a bit of boost. I tryed turboin my 4k it was to much effort and not much gain so i just put a v6 in it lol
turbo 4k
turbo 5k
Look at Taz_Rx's turbo build rides thread for some good info on setting up a turbo K motor. Click Here.
Your english is pretty damn good compared to some of the gronks we get here, you only misspelt definatly, should be definitely.
...don't put the 4k head on! The higher compresson is not good for turboing blow the head of with a bit of boost...
This is totally incorrect mate. 4K head will either lower compression (dished piston 5K) or will stay nominally the same (flat piston 5K) and is better suited for a turbo.
  • Upvote 1
I can second that, I have both heads taken apart. The 4k has a shite load more combustion chamber in the head.
Hmmmm, so i have a spare 4k with a spare 5k head....
Grenade motor anyone?
  • Upvote 1
5K = more power potential (1.5 vs 1.3L)
4K easy/cheap to replace if/when it goes bang
So maybe build your turbo kit up on the 4K, get used to it, then swap to built 5K?
buy some steem pipe a welder and go for it dude. or j pipe for sure.
My manifold was over $700 :bash: ...... Can get a J-pipe made for under $100 though.
Oh and I didn't notice a whole lot of difference in going from a 4ktc to a 5ktc, little bit more torque maybe.
Edited by Taz_Rx
