hi everyone.
recently replaced the starter motor in my '72 ke20 with a rebuilt one and of course removed the battery when doing so.
my problem is now that the car is fixed, the indicators seem to have called it quits all together.
went around and checked all bulbs individually, they all appear fine.
the single fuse above the drivers footwell marked 'turn' has not blown.
went into the column indicator switch and gave it a good clean out making sure to check all the contacts etc and it too is fine.
checked the flasher unit and it has been replaced recently and appears in good condition, and made sure to check the connections to and from the unit itself and nothing appears out of ordinary.
is there something i am missing here? possibly another fusebox somewhere?
seems strange that both the hazards and the indicators no longer work after removing and replacing the battery.
can someone please shed some light on the situation? it might be just that i am overlooking a certain aspect of the problem without realising, or perhaps there is more to it.
regards,
todd.
