ke20 king Posted September 28, 2010 Report Posted September 28, 2010 difference between 5k and 3k oil pump Can u use a 3k one on a worked 5k and how do u reshim the oil pumps thanks Quote
philbey Posted September 28, 2010 Report Posted September 28, 2010 (edited) I don't think they're any different. You pull the spring out of the pressure relief valve and put a 2mm washer under it. If you have the pump in front of you, just pull it apart and you'll see what I mean. Very simple piece of gear. Edited September 28, 2010 by philbey Quote
Felix Posted September 28, 2010 Report Posted September 28, 2010 Pretty sure 3k's have a shallower sump, so a 3k pump might sit a bit high above the floor of a 5k sump. Quote
philbey Posted September 29, 2010 Report Posted September 29, 2010 hmm interesting point felix. I do have one of each sump at home I'll compare. But I've got 3 pumps that I swear are identical. Quote
camerondownunder88 Posted September 29, 2010 Report Posted September 29, 2010 Early K motor pumps also have a detachable oil pick up. There the ones you want when up righting a K motor so you can take it off make a new pick up and off you go :) Also TRD for the K oil pump made a spacer that went between body and pick up and put a T motor oil pump gear in it. Higher flow then so that is an option if your looking at modding it. Cameron Quote
TRD ke70 Posted September 29, 2010 Report Posted September 29, 2010 On the money there Cam,3k's (not sure if all of them are the same) has a steel pick up that unbolts from the oil pump housing and is the one to use when upriting a K engine. 7k's also have an unbolt-able pick up, almost identical to the 3k. Quote
philbey Posted September 29, 2010 Report Posted September 29, 2010 interesting then because my 3k didn't have one of them I'm certain, I would have noticed a detachable pickup, so it's been changed at some point. Quote
