Redwarf Posted September 13, 2004 Report Posted September 13, 2004 Funny that, I've only crapped one gearbox, half a dozen axles and three diffs in twelve years of racing. Must not be trying hard enough..... Quote
irokin Posted September 13, 2004 Report Posted September 13, 2004 Funny that, I've only crapped one gearbox, half a dozen axles and three diffs in twelve years of racing. Must not be trying hard enough..... what surface to you break the majority of bits on?? I can't imagine dirt being too hard...altho you have got those supergripper tyres :P Quote
Felix Posted September 13, 2004 Report Posted September 13, 2004 i was pretty mad when i was younger :P i haven't broken anything in my ke15, which has a lot more power than the old '30. i don't dump it in first or anything stupid these days, although i have done many flat changes into second with no issues. think a lighter car helps. have never broken an axle in a corolla. do they snap off the spline in the diff, and make it hard to get the spline out like on old holders? driving on dirt would put a lot more load on the drivetrain, especially through ruts and on corrugated roads i would think. the load wouldn't be constant like on the bitumen, with the surface changing all the time. Quote
demuire Posted September 13, 2004 Report Posted September 13, 2004 I've broken 3 gearboxes since April this year... Something must be wrong with me :P Quote
Teddy Posted September 13, 2004 Report Posted September 13, 2004 Teddys Kill List So Far : 1 x 30% Clutch wear in one session (learning how to hill start)... :P ! 1 x gea... oh hang on ; can't say that one :P thats about it :) Quote
Redwarf Posted September 14, 2004 Report Posted September 14, 2004 Locked diffs aren't super axle friendly. Yes Doug, they break at the spline end, so diff out to extract the end. Funnily enough, they're usually not too hard to get out of the diff. I find I have most difficulty with them at/ after Bitumen motorkhanas. Quote
Felix Posted September 14, 2004 Report Posted September 14, 2004 ok, haven't run a locker as yet. i have plans to put one in the ke10 after rego. i'm sure i will experience it sooner or later. are you any good at welding diffs Rob? Quote
Redwarf Posted September 14, 2004 Report Posted September 14, 2004 PM me when time comes, and I'll give you the name of the guy who does (and tecnically doesn't) do mine. I will guarantee that he welds will never break. Behold: Quote
Redwarf Posted September 14, 2004 Report Posted September 14, 2004 Most people usually weld them like this, though. This is my old 4.3:1 which lasted six or seven years before finally letting go the pinion teeth.... Quote
Nitephyre Posted September 14, 2004 Report Posted September 14, 2004 so what does welding the diff do again? Quote
Felix Posted September 14, 2004 Report Posted September 14, 2004 the locker is the poor mans LSD. it stops you frying the inside rear tyre when you are working the car hard, but has a lot of negatives for a daily driver. it makes both rear tyres rotate at the same speed the whole time, so whenever you turn one or both tyres will break traction, or the car will want to push and understeer. rear tyre wear is about 3 times faster than a normal open diff. i want one for my ke10 as it will only be used for motorsport purposes, and will be getting club rego. it is ideal in this respect as the car will want to slide far more easily and predictably once provoked into oversteer. the quickest cars at the motorkhanas generally are running lockers (like Rob), and have hydraulic handbrakes. also lockers are awesome for drive out of corners and straight line acceleration. Quote
Redwarf Posted September 14, 2004 Report Posted September 14, 2004 ...... and snapping axles! :P Quote
demuire Posted September 14, 2004 Report Posted September 14, 2004 the quickest cars at the motorkhanas generally are running lockers (like Rob) I think it would be safer to say that the quickest cars are generally the ones with LSD's or lockers. LSD's are in most ways far superior to a locker. I've driven both, and I'd take an LSD any day... That said, LSD's are a shiteload more expensive... Quote
Teddy Posted September 14, 2004 Report Posted September 14, 2004 the quickest cars at the motorkhanas generally are running lockers (like Rob) I think it would be safer to say that the quickest cars are generally the ones with LSD's or lockers. LSD's are in most ways far superior to a locker. I've driven both, and I'd take an LSD any day... That said, LSD's are a shiteload more expensive... but then theres mumbles (Paul) and his blue sprinter, well at the last motorkhana anway... good god he can move that car !!!!!! Quote
